Author Topic: what is this for??  (Read 3032 times)
Offline rfn_hodgson
what is this for??
« on: 05 August 2013, 20:21 »
hello felles i have seen a few mk4 without this... its the black box on top of one of the coilpacks
what exactly is it for?/
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
Re: what is this for??
« Reply #1 on: 05 August 2013, 20:30 »
if I remember correctly it is called the vacuum reservoir. I got rid of mine when I did the N249 delete.  I think it was the N249 delete.
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #2 on: 05 August 2013, 20:42 »
As above, its stores vacuum to operate diverter valve if needed. Its removal gives a crisper dv noise through the induction. Its removal requires a bit of reworking of the vacuum piping and a resistor fitted but plenty guides around on n249 removal.
Offline Nino
  • Insta - F6UGA
« Reply #3 on: 07 August 2013, 10:28 »
^^^ its only found on the AUM engines, as above it stores a vacume of air for the n249 valve that controls the DV. I'd recommend doing an n249 delete/bypass (see the how to section) by doing that your DV dumps atmospherically as apposed to "controlled" by a valve which often fails or dumps too early. You will also feel slightly better throttle response.  :)
Current - MK6 GTi Edition 35
Offline rfn_hodgson
« Reply #4 on: 07 August 2013, 10:44 »
mine is the AUQ block and thats a pic of my engine and im waiting for some piping to turn up so i can do the n249 delete :) love little projects like this :)
Offline brewey
« Reply #5 on: 07 August 2013, 13:46 »
I have the reservoir on my ARZ.
2000 1.8T ARZ - OEM+
Offline Nino
  • Insta - F6UGA
« Reply #6 on: 07 August 2013, 19:29 »
My bad, just going by what I was previously told  :undecided:
However the rest of my statement stands  :nerd:
