Author Topic: MK7 GTD - Real Life MPG  (Read 439634 times)
Offline mcmaddy
Re: MK7 GTD - Real Life MPG
« Reply #1050 on: 07 September 2015, 08:15 »
Only ever used shell or esso and find shell slightly better than esso. We have esso premium diesel in Sunderland but never used any.
Offline Diehammer
« Reply #1051 on: 14 September 2015, 11:16 »
I am going to give premium a shot next as prices are low just now. Regular is 106.9 & premium is 117.9
Golf GTD MK7 5 door Manual, Carbon Grey, Keyless Entry, Rear View Camera.
Ordered 26/02/15  Build Week Confirmed 24/04/15 (BW21) Stage 5a 19/05/15 Stage 5b 21/05/15 Stage 5c 29/05/15 Stage 6 02/06/15 Stage 7 04/06/15 Pick Up 06/06/15
Offline monkeyhanger
« Reply #1052 on: 27 September 2015, 21:26 »
Slightly offtopic, but related to VAG TDI mpg.
As you might've seen in another thread, we've taken delivery of a new Audi A1 1.6TDI Sport. The missus is taking her driving test (at 38 years old) in a month's time after a 12 year break from trying.
So i've decided to give the 7R a rest and run in her new A1. I've done about 90 miles in it over 3 trips, getting a consistent 56mpg. I second guess the car's gear change suggestions - we seem to be on the same wavelength.
Took the missus out on the L plates today, she was driving up the north Sea coast from Tynemouth to Blyth and back.
The missus was almost always 1 gear lower than I would've been in (sitting at 20mph in 2nd, 30mph in 3rd, not hitting 4th unless doing 45mph), and on that 18 mile round trip I was astounded to see the car had given 65mpg indicated. Driving the car in a way that would seem to be uneconomical has given the best result.  :undecided:
Diehammer- unless you want your injection system cleaning, I would avoid Shell V-power diesel - it is less calorific than regular diesel, so will give you fewer mpg.
My GTD ran best on BP and Esso. A string of pre EU6 TDIs owned always had a preference for Shell, not the 7GTD in my experience.
Offline p3asa
« Reply #1053 on: 27 September 2015, 23:16 »
I don't think I'd be babying the car like that in its first few miles by changing up when the car was telling me to as I always think it tells you to change far too early and almost labouring the car.
« Reply #1054 on: 28 September 2015, 11:51 »
I was giving it a bit of welly when getting up to my desired speed, but once there i'm quite economical. Maybe i'll have it hang on to the gears a little longer when going around the 20/30/40 roads. Most of my driving was 50-80mph, so makes sense to be sat in 5th at 80.
Offline Diehammer
« Reply #1055 on: 30 September 2015, 22:21 »
There is only 1 shell garage in a radius of 10 miles so that won't be an issue monkeyhanger. I would most likely use esso as BP is really expensive at the 2 garages here and one is right across from Grangemouth Refinery.
Offline Restlessnative
« Reply #1056 on: 21 October 2015, 23:15 »
First ever tankful brim to brim today.Horrified to see my GTD had done only 44.3 mpg.Computer was saying 47mpg so i knew it was going to be low.
Current: Golf GTD MK7  3 door manual carbon grey.
Offline fredgroves
« Reply #1057 on: 22 October 2015, 09:05 »
Do you mean the car said 47mpg but your actual fuel usage calculation based on delivered volume was 44.3?
Doesn't surprise me to be honest, especially if you have had a few cold morning commutes. Starting from sub ten degrees and you will see fuel usage increase.
Equally, my trip home last night gave me 57.6mpg - a new home commute record for me :) It was 13.5 Celsius and the journey was about 40 miles.
Enjoy it while we can though, the super nasty winter sludge is coming... 6 months of poor economy.
Offline Websta24
« Reply #1058 on: 22 October 2015, 10:02 »
My trip is stating 46mpg long term so 2400 miles from brand new....most journeys are sub 5miles at the moment 2 miles to and 2 miles from etc so im quite happy with it
Longer runs im seeing 50mpg+
Offline J400uk
« Reply #1059 on: 22 October 2015, 19:32 »
This week I've got above 50mpg every day, even saw 56 today. I haven't been driving it differently and still using Shell fuel so not sure what's changed from last week when it was sub 50! Just over 8000 miles on the clock now so well run in, 4 months old.
2015 Golf GTD 2.0 TDI 184 PS 6-speed DSG 5 Door Tornado Red
