Author Topic: warning to all mk2 golf owners!  (Read 11078 times)
Offline gazareth
« on: 28 July 2013, 00:43 »
hey guys went to remove a wheel on my mk2 golf only to discover the darn jack supplied with the car doesn't even lift the wheel off the ground. so I would advise a trial run to all concerned lol
Offline danny_p
Re: warning to all mk2 golf owners!
« Reply #1 on: 28 July 2013, 00:56 »
the standard jacks work just fine.  yours must be ether broken or wrong one
all the VW's have gone bar 1.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #2 on: 28 July 2013, 01:28 »
+1
Works fine... But they aren't called "Widow Makers" For no Reason!!!
For More Info Click To See;
Offline Sgt_Lemon
  • 8v owners club
« Reply #3 on: 28 July 2013, 01:43 »
I only use a trolley jack. However I don't have a tire iron or jack in my boot so having a spare wheel in there is a waste of time atm. Either need to get a jack or ditch the wheel.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #4 on: 28 July 2013, 01:59 »
Buy a cheap & portable trolley Jack. Clarke did one in a plastic carry case for about £20.00
Offline gazareth
« Reply #5 on: 28 July 2013, 12:12 »
yeah I suppose it could be wrong jack but cant understand why. oh well. I threw a small block of wood in the boot alongside it just thick enough to let it get wheel off ground.
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #6 on: 28 July 2013, 17:04 »
OP, did you place the jack under the lowest edge of the sill? Where it's supposed to go!
The egg cup like points under the car are for lifting on a 2 post ramp only, they will not take the weight of the car, unless all four are used together, and even then on a slightly rotten floor, even this is questionable!
Thom
Offline gazareth
« Reply #7 on: 28 July 2013, 18:10 »
yeah it was on sill flange. just in behind that little flap in the side skirt. when I use the trolley jack at work I put it under them egg cup thingys. works mint and no sign of floor deforming thankfully.
VW BUSH
« Reply #8 on: 28 July 2013, 20:59 »
Still do and with discount I paid 16 pounds
Offline Waspy
« Reply #9 on: 29 July 2013, 17:18 »
I own a trolly jack, however for a while the car was too low for the jack, so had to use the supplied jack (which was fine). Now the car has clearance for the trolly I dont know where the jacking points are, haha. Anyone got any advice on where to jack from?
