Author Topic: Headlining - who's re-trimed?  (Read 17494 times)
Offline vwscottie
Re: Headlining - who's re-trimed?
« Reply #30 on: 18 August 2013, 23:01 »
High temp contact glue like trim fix will do the job. I used two cans to do mine but ideally should have used three two was a cutting it a bit fine.
Offline Screech16v
  • MK3 20vt AGU
Offline owenfranssen
« Reply #32 on: 18 August 2013, 23:37 »
Thanks guys just ordered 3 cans of FastFix, lets try this again now :P
Offline Screech16v
  • MK3 20vt AGU
« Reply #33 on: 19 August 2013, 20:43 »
 :cool: High temp ftw
Offline harlemex
« Reply #34 on: 10 September 2013, 15:06 »
Deano reckons pritt stick does the job, he went nuts when i said I wouldnt reccommend it.
Offline spudboy6
  • Just like a golf ......
« Reply #35 on: 10 September 2013, 20:59 »
When I done mine with high temp glue was last summer.  Since having a few hot days the lining dropped , anyways the best solution without takin it out again was a staple gun worked a treat never dropped since :)
Offline jnufcuk
« Reply #36 on: 20 September 2013, 14:47 »
how easy to take the plastic bits off? Thinking about just sorucing an interior then painting/ retrimming then swap over? then sell old one on?
Offline tshirt2k
  • Been there...Done that...
« Reply #37 on: 27 September 2013, 11:40 »
Even high temp stuff won't stick very well if it hasn't been applied properly.
It has to be left for a few mins to go tacky 1st, and apply to both sides.
Mk3 ABF 16VT Megasquirt V3
Offline Vdubbster
« Reply #38 on: 27 September 2013, 13:28 »
I did this year's back. After one failed attempt I got another liner and used acoustic carpet and a tin of glue which brushed on. Check my old thread it might help:
http://www.golfgtiforum.co.uk/index.php?topic=83597.msg684943#msg684943
Offline Vdubbster
« Reply #39 on: 27 September 2013, 13:35 »
I got hold of black pillars and black visors.  Looked very slick and minimal  :smiley:
