Author Topic: Anyone know about drills?  (Read 2738 times)
Offline tweed
Re: Anyone know about drills?
« Reply #10 on: 27 July 2013, 16:09 »
I havent seen one. Only normal drill chuck that fits into a sds, doesn't mean there isn't one.
 I have two of these but 110 http://www.ebay.co.uk/itm/AEG-KH28-XE-28mm-SDS-3-Mode-Hammer-Drill-QCC-240-Vol-/260815498371?pt=UK_Home_Garden_PowerTools_SM&hash=item3cb9d0ac83
and a cordless dewalt sds.
Offline tweed
« Reply #11 on: 27 July 2013, 16:13 »
It's only a hole, can't be that hard.  I also need something with more grunt for making a trench in my conctre lounge floor soon to run cables across the room.
chase two lines with a grinder first. Inch or two apart then use the sds hammer chisel to make the channel
Offline bobbarley
  • I'm kind of a big deal...
« Reply #12 on: 27 July 2013, 16:16 »
Bit out of my price range  :grin:
Good advice, cheers.  That's exactly what I'm looking to do.  My television is going to be wll mounted on the opposite side of the room from where the phone/fibre, Sky and aerial is  :undecided:  So need to route the cables all the way across.  Figured do a proper job of it  :smiley:
Offline justalex81
« Reply #13 on: 27 July 2013, 16:21 »
personally i wouldn't go cheaper/less powerful than this if you want it to last:
http://www.screwfix.com/p/bosch-2kg-sds-plus-drill-gbh2000-240v/87453
Spend a bit more and get a very good drill:
http://www.screwfix.com/p/makita-hr2470-2-2kg-sds-plus-drill-240v/99908
VW BUSH
« Reply #14 on: 27 July 2013, 17:41 »
I have a load of drills like yours with the shank spun down to fit my cordless 10 and 12mm chucks.
Offline danny_p
« Reply #15 on: 28 July 2013, 00:00 »
grind the shank down,  it's a bodge but your not useing it every day.
or get an SDS bit an a cheep 6kg drill esp if you want to do lots of chisseling
all the VW's have gone bar 1.
Offline hobbiniho
« Reply #16 on: 28 July 2013, 14:42 »
when you are lookin for hammer drills especially if you are going to be doing quite a lot of chiseling then you need to look  for one with a high joule rating as that is how hard it can hit, and the harder it can hit the better it will be at chiseling
