Author Topic: Can you put n75 valve on wrong way round?  (Read 1202 times)
Offline fogster
« on: 26 July 2013, 14:31 »
Is it possible to put n75 valve on wrong way round?
I've got a n75 j valve and the long tube is opposite side to the one I've taken off, I've put the new one on the same way round but car hesitating now.
Could it be the car learning the new valve?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Can you put n75 valve on wrong way round?
« Reply #1 on: 26 July 2013, 15:09 »
If your car isn't mapped for the N75J it won't know what to do with it...
Offline davemk4
« Reply #2 on: 26 July 2013, 15:16 »
i tried and J and gave a mental spike and kick of power but boost was all over place
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline ben.banks21
« Reply #3 on: 26 July 2013, 15:52 »
n75 j valve is useless
Offline fogster
« Reply #4 on: 26 July 2013, 16:45 »
Ok thanks for the replies, I'll take it off again then.
