Author Topic: GTI - First batch issues?  (Read 17673 times)
Offline monkeyhanger
Re: GTI - First batch issues?
« Reply #30 on: 26 July 2013, 21:10 »
You only hear about the bad DSG boxes. My Dad ran his MK5 170TDI GT DSG (that had significantly more torque than the GTI of the time) for nigh on 120k miles and the DSG box never missed a beat. 40k miles of that was with tuning box to 200PS and my dad made plenty of use of the extra power - the unit was bullet-proof. Far more to worry about with 7 speed dry clutch.
Offline DougL
« Reply #31 on: 26 July 2013, 21:22 »
Which means that there are quite a few about. The single evidence of your dad's car is completely anecdotal.
Tornado Red GTI 3dr manual
Previous Golfs Mk1 GLS and GL, Mk2 GL and Driver, Mk3 GL, Mk4 GT TDI, Mk6 TDI (and a Mk2 Scirocco 20 years ago)
« Reply #32 on: 26 July 2013, 21:51 »
I know around 6 people at work with Golf 2.0TDIs and DSG (Golfs/Passat CCs/Sciroccos/A3) and none have had issues. The 7 speed dry clutch is definitely the one to be concerned with and you won't see that on a 2.0 VAG unit in TDI or TSI.
The fact you only hear about the bad ones is completely anecdotal. If 1 in 100 were to fail would you consider it an issue? The 99 wouldn't be broadcasting how trouble-free their DSGs were, but you'd hear about the 1 bad one. If you keep your Golf beyond the warranty and it hasn't played up in warranty it's quite unlikely to start playing up just out of warranty (although it is possible).
VWs aren't the most reliable cars - my 2 MK5 Golfs had plenty of warranty work lavished upon them, which is a good thing - all the niggles were picked up early. A faulty component or incorrect installation is far likely to fail earlier than later.
The 6 speed wet box has been with us a long time and is far more established than the newer 7 speed dry unit. They've had plenty of time to perfect it if it was a troublesome unit.
« Last Edit: 26 July 2013, 22:01 by monkeyhanger »
Offline SA-GTI
« Reply #33 on: 01 August 2013, 15:14 »
Locally reported issues on the GTI - noisy front suspension, fix is to grease the top shock mounts and add some sort of sleeve.
Offline Bill_the_Bear
  • Yes! Wait a minute... No!
« Reply #34 on: 01 August 2013, 15:25 »
By locally I assume you mean SA?  I wonder if this is being reported anywhere else or if it could be environment related.
Offline SA-GTI
« Reply #35 on: 01 August 2013, 15:29 »
Yes, local to SA. I'm not saying that it is only happening in SA but all of the reports I read are from SA this far.
Offline SA-GTI
« Reply #36 on: 01 August 2013, 15:30 »
Any of you UK guys experiencing odd front suspension noises?
« Reply #37 on: 01 August 2013, 16:58 »
Nope - we're all still waiting for our cars!  :whistle:
Offline SA-GTI
« Reply #38 on: 19 August 2013, 18:08 »
Just wanted to keep this post updated, my GTI has the squeaky/creaking front suspension issue now. There is also a lot of road noise and wind noise from around the windows (4 door). My front discs look like sh!t after only 2000km with 1500 of that being long distance highway driving.
Offline Jimble
  • Moderator
« Reply #39 on: 19 August 2013, 18:55 »
In what way do your discs look like sh!t?
