Author Topic: Rocker and inlet bolts  (Read 3699 times)
Offline Nino
« on: 24 July 2013, 12:52 »
Hey giys just wondered if anyone knew what the bolts on the rocker cover and the bolts on the inlet had to be fully torqd at and in what order they need to be tightened in and in what process e.g must i torq the bolts to a cetain spec all round then go back in a certain order to fully tighten?
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline limmy
Re: Rocker and inlet bolts
« Reply #1 on: 24 July 2013, 14:20 »
This is what i used:
Inlet Manifold - bolts to block - 6Nm
Rocker cover - nuts to block - 10Nm
Regarding sequence, have a look at thoses DIY guides i sent you awhile back as i think its mentioned in there
Offline Nino
« Reply #2 on: 24 July 2013, 22:19 »
Thanks a lot ill see if I can find it :)
jamie16v
« Reply #3 on: 25 July 2013, 15:12 »
whilst on this topic, anybody know the best place to get new injector seats and how much they are?
cheers.
Offline mike1990
« Reply #4 on: 25 July 2013, 16:48 »
According to my AutoData, it says the rocker and inlet are both 10Nm.
Tighten them in a sequence starting in the middle and work your way to through them from left to right and right to left
Offline Nino
« Reply #5 on: 25 July 2013, 18:07 »
cheers.
I got mine from a supplyer on ebay see here....
http://www.ebay.co.uk/itm/181164148399?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_350wt_1141
Offline Nino
« Reply #6 on: 25 July 2013, 18:08 »
Thanks for that info :)
Offline mike1990
« Reply #7 on: 25 July 2013, 18:22 »
No problem :)
jamie16v
« Reply #8 on: 25 July 2013, 21:10 »
cheers.
they no good for the large port head?.. (AGU)
Offline Nino
« Reply #9 on: 25 July 2013, 21:10 »
Does anyone also know what gasket sealent I could buy from eBay and where to apply it on the rocker cover gasket?
