Author Topic: Where does this pipe go?  (Read 2855 times)
Offline Nino
Re: Where does this pipe go?
« Reply #20 on: 16 July 2013, 07:29 »
That's strange, looks like some kind of coolant pipe to me, also you can see a clip that it should be sitting in just to the left of it.
Does the pipe have a part number printed onit? Also it looks like its been cut to me.
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline fogster
« Reply #21 on: 16 July 2013, 16:09 »
No there's no part number on the pipe, thanks to James2 we think it should go onto the temp sensor, he's taking some pics of his today hopefully to see where it should go.
The pipe that's connected goes from the temp sensor straight into the heater through the bulkhead.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #22 on: 16 July 2013, 20:39 »
looks like they've just left the old one in there after replacing it
Offline james2
  • No scammers please.
« Reply #23 on: 17 July 2013, 14:22 »
yeah looks like its just been replaced and left there, it connects up to the bulkhead pipe you showed in picture behind dv.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline fogster
Re: Where does this pipe go? Now sorted
« Reply #24 on: 21 July 2013, 13:21 »
I've have now sorted out the mystery pipe.
Somebody had disconnected the pipes from the heater matrix.
Both ends of the pipe connected and job done.
No visible leaks so why it was disconnected is a mystery.
Thanks for all the help.
