Author Topic: oil sensor??  (Read 2074 times)
Offline lee1989
Re: oil sensor??
« Reply #20 on: 16 August 2013, 16:45 »
Ok cheers mate just thought id ask as it didnt go until i done an oil change so thought it could have been that lol cheers
Offline topher
  • Administrator
  • fully functioning
Re: oil sensor??
« Reply #21 on: 16 August 2013, 19:07 »
disconnect the battery for 10 minutes, if it cures it then your bonnet switch isn't working. if it doesn't cure it then its either time for an oil change and new sensor, or you might get under there and see broken wires its always worth following the loom up as far as you can see. Pop the plastic shielding off and take a look.
or you could just disable the warning with vagcom and use the dipstick weekly like we're all supposed to :grin:
Offline lee1989
Re: oil sensor??
« Reply #22 on: 17 August 2013, 08:09 »
I had the battery out the other week for a while because i had to sort my starter motor out and that didnt fix it, also i had a look at the wiring to check it wiring was good but it was unpluged, pluged it back in still the same, i think ill order a new 1 now and try that see if that works it hasnt long had an oil change but im going to do it again because of the amount of miles a week i do, just out of interest what oil would u recommend? CHeers
