Author Topic: MPG at 80-85  (Read 7002 times)
Offline Gordor
Re: MPG at 80-85
« Reply #10 on: 05 July 2013, 22:02 »
80 mph Autoroute/Autobahn kills the mpg. I'd reckon you'd be lucky to see 45mpg. On my 1.6tdi bluemotion, the figure dips into the high 40s. On a long A road run, it gets 55 - 60 mpg.
Doesn't the 1.6tdi only have 5 forward gears though? That would make a massive difference on the motorway surely?
GTD Pure White : 19" Santiago's : Winter Pack : Dynaudio : Park Assist : High Beam Assist
Offline monkeyhanger
Re: MPG at 80-85
« Reply #11 on: 05 July 2013, 22:03 »
Agree to a point but the main factor at these sort of speeds is drag. I just did two 400 mile days from Barcelona to St Malo (on a scooter) and the motorway riding dropped the mileage per tank (at 80mph) from 160 to 120.
Aye, pushing through the air at 85mph is a lot harder than 60mph, but even so, my dad achieved 45mpg in his new GTD DSG at 85mph on a long journey under the worst of circumstances (aircon working hard, new car not run in, DSG has a greater penalty in fuel as it is geared lower than the manual). I think the OP can easily expect this at a minimum considering my dad's less than efficient cruising speed and the achilles heel of DSG economy (assuming he could be getting a manual).
That 1.6TDI (105PS I assume, not 90PS version which will be working even harder) will be working a lot harder to overcome the drag than the GTD, so a car doing 70% of it's potential output vs a car doing 40% of it's potential output (both probably outputting about 75PS to maintain that speed) will be a lot thirstier even though on paper it is 10% more efficient on the combined cycle.
Offline mcmaddy
Re: MPG at 80-85
« Reply #12 on: 05 July 2013, 22:04 »
I've found the sweet spot on all of the diesel vag engines I've had is 82mph
Offline ajmoir36
Re: MPG at 80-85
« Reply #13 on: 05 July 2013, 22:06 »
I have actually found peak mpg at 52mph (mk6 GTD)
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Re: MPG at 80-85
« Reply #14 on: 05 July 2013, 22:14 »
I find the 2.0TDI has the least penalty for mpg at the higher cruising speeds. They are most efficient at 55-60mph, but the trade off above that to 80mph is relatively small. Sounds like the OP does a canny bit of high speed cruising, especially in Europe where he can take advantage of significantly cheaper diesel prices.
You'll be looking to 40mpg on a long trip at 80-85mph in a GTI and 60mpg on a GTD when they're run in (assumed manual transmission). It's up to the OP to decide whether they do the miles to consider the GTD a better buy for them for what they'll be looking to do with it.
