Author Topic: MOT failure - Emmisions  (Read 3164 times)
Offline laurenceyon
Re: MOT failure - Emmisions
« Reply #10 on: 04 July 2013, 10:53 »
Haha - oh I do drive her. - Not to the point where it's thrashed but these cars aren't designed for driving like a wand..
I'll do the stem seals on Saturday. Can anybody hook me up with a user guide - I did search  :wink:
« Last Edit: 04 July 2013, 11:33 by laurenceyon »
Hi my name is Laurence, I'm very much like you. Only better.
Offline search
« Reply #11 on: 04 July 2013, 12:05 »
mine was high but the guy took my breather pipe off the filter housing then it passed lol.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline Sgt_Lemon
  • 8v owners club
« Reply #12 on: 04 July 2013, 16:48 »
To do the valve stem seals, with the head off. Remove cam, and tappets. Remove valves with valve spring compressor. Now remove the old valve stem seals. When installing the new ones you don't want to put them in too hard or too tight. Either damage the valve guides or it leaks. I used a socket and extension arm over the seal and gently tapped it down. Used a 9 sided socket slightly smaller than the seal, just tapped it down till it was tight enough to pull the socket off not the seal off. Does that help?
Offline laurenceyon
« Reply #13 on: 05 July 2013, 08:15 »
I think I better book it into a vw garage. Thanks for your help anyway. At least I know what the issue is, hopefully it's not the piston rings. But i'n sure we'll soon find out, eh!
What a ball ache.
Offline gazareth
« Reply #14 on: 05 July 2013, 21:30 »
first thing to ask when you take it to garage is. can they do it with the head on the car. it will save you some cash in labour and the cost of a new head gasket set. the thing is once to start removing heads you could end up with a lot of extra costs. like grinding valves/renewing guides/skimming. and if the engine is running great I would just go for the stem seals on their own. but at the end of the day its your choice as to how good or how cheap a fix you want.
Offline Sgt_Lemon
  • 8v owners club
« Reply #15 on: 05 July 2013, 22:34 »
It can be done with the head still on the car, it's just more awkward to compress the springs to drop the valves. Easier to ask a garage, you need special tools to do it yourself.
Offline gazareth
« Reply #16 on: 05 July 2013, 22:58 »
yeah that's true but check first if the garage has the right tools to do it in a reasonable amount of time. like an adaptor to pressurise cylinders with air to keep valves up/proper spring compressor and stem seal puller. these seals can be really on there tight and its very easy to damage the top of the guide if your not careful.
