Author Topic: Discover media - contacts photos and music album art?  (Read 103396 times)
Offline mortimerchris
Re: Discover media - contacts photos and music album art?
« Reply #100 on: 19 August 2013, 15:41 »
Yeah it's a great buy, and great to see people making good use of that SD card slot! :grin:
Yeah but what do you do with the other SD slot? :huh:
You put maps in it when you've hacked your regular head unit into Nav. :grin:
Are you grinning because this is possible? If so where is the guide?
Ordered a Golf GTI DSG Performance Pack in Pure White with Keyless Entry, Dynaudio, Rear View Camera and Panoramic Roof.
Currently driving a Scirocco 170 GT in Night Blue with Bluetooth, Rear Parking Sensors, DAB and Dynaudio.
Offline AAddict
« Reply #101 on: 19 August 2013, 16:05 »
I'm waiting for someone much clever than me to work out if it's possible. I reckon it's juts software plus a GPS antenna, but that's only a hunch.
Cancelled GTI, M135i beast mode.
Offline monkeyhanger
« Reply #102 on: 19 August 2013, 18:14 »
Just got the Class 10 32GB Sandisk Ultra from Gizzmo Heaven for £15.53 using code Gizzmo5
http://www.gizzmoheaven.com/SanDisk-32GB-Ultra-Class-10-SDHC-Card-Memory-Card-30MB-s/s199918/c581/Product.html
Just gave you some heat on hotuk deals. Not the best SD card deal i've ever got (Sandisk extreme III XCSD 80mbps 64Gb for £25), but best I can see right now and more than enough for the car.
Offline AAddict
« Reply #103 on: 22 August 2013, 12:55 »
All credit to EliteBajan for this:
This looks very promising, a gadget that lets you mirror whatever your smartphone is doing on the VW head unit. Endless possibilities, second video on this post:
http://www.golfgtiforum.co.uk/index.php?topic=245312.msg2372832#msg2372832
Anyone read Korean?
http://indiwork.co.kr/cart/?doc=cart/item.php&it_id=1375695673
Offline EliteBajan
« Reply #104 on: 22 August 2013, 21:49 »
Thanks for the props!!
It doesn't look like a cheap option though.
http://m.t3.com/news/kivic-one-brings-airplay-dlna-to-your-car
Candy White Mk6 GTI 2012 - Bog standard! Weight saving you understand (stolen March 2013)
Solid Black Mk7 5dr, Leather, Performance Pack & Dynaudio.
Offline Roonaldo
« Reply #105 on: 27 August 2013, 17:49 »
New member, should be picking up my new GTI next week.
Was wondering how iTunes playlists were handled with the SD card, if at all?
Offline Gryzor
  • Go white, or go home!
« Reply #106 on: 27 August 2013, 22:25 »
Hi, and welcome to the forums!
I don't honestly know - I've read around and can't see anything about supporting playlists from the SD card.  Maybe somebody here who owns one can test or confirm one way or the other? Failing that I'll have a test myself after I get my GTI on Sunday.  I don't have many playlists, but am I intrigued myself now as I'll be using an SD card for my music.
Clearly if you are streaming from your phone via a playlist, that will work just fine.
Pure White Mk7 GTI (5dr, Manual)
Options: Reverse Camera, Keyless, Adaptive Chasis, Climate Screen, Winter Pack, Discover Nav, Advanced Phone Prep
Offline Roonaldo
« Reply #107 on: 28 August 2013, 17:16 »
Thanks, if you don't mind checking, please let me know as would prefer to use SD card. Think my date will be 2 or 3 weeks.
Offline Roonaldo
« Reply #108 on: 01 September 2013, 17:10 »
Did you get your car? Bet you're loving it. Probably too busy, but any joy with checking this?
Offline Gryzor
« Reply #109 on: 02 September 2013, 13:17 »
I did get my car, and yeah, loving every minute of it!  I saw the thread and remembered about the playlist thing so I've had a bit of a play about.  Basically, I use iTunes for one thing, and one thing only - to get my own music collection onto my iDevices.  So, I'm just going to assume that a playlist playing on your iPhone, streaming via Bluetooth will work just fine.  You can export playlists, but from what I read, the output will need tweaking.
However, I did manually create the simplest of playlists for use on an SD card as follows.
  • Created a folder at the root of my SD card called #PlayLists so that it's at the top
  • Created a TestPlayList.m3u file inside that folder
  • Added a few entries in the format ..\artistfolder\albumfolder\songname.mp3
This worked absolutely fine.  All of my music is stored on my SD card in Artist/Album/Song format, but you may have your folders set up different so the paths you create inside the playlist would need to be altered to match.
I don't actually bother with playlists myself, but I know there is plenty of software out there that will create a standard .m3u playlist for you based on the songs that you want.
