Author Topic: After weeks of deliberation - brakes finally ordered !!  (Read 7999 times)
Offline Philip James
Re: After weeks of deliberation - brakes finally ordered !!
« Reply #10 on: 28 June 2013, 21:43 »
+1. ECP Pagid brakes are utter tripe. Dealer for OE.
Just found the perfect GTi...
Offline jhunter_83
« Reply #11 on: 28 June 2013, 23:15 »
There is good and bad views over everything, everyone has their own opinion.
Have you had experience with pagid discs?
2010 Silver Golf GTi 5 Door, Poverty spec wheels, RCD510 Bluetooth and DAB, Pagid Discs and Tarox Strada Pads
Offline gazareth
« Reply #12 on: 28 June 2013, 23:50 »
whats to say the dealers aren't using crap from china and repacking it??? the dealers are all about profits. nothing else. they don't care what junk they sell you.
« Reply #13 on: 29 June 2013, 00:15 »
^^^Good point. We'll never know.
Offline Beddie
« Reply #15 on: 29 June 2013, 06:42 »
Yes I've had experience with Pagid discs from ECP and also experience of them before ECP bought the exclusive rights to the Pagid brand and the difference in quality and longevity is easily noticeable...
Many others over on the mk5golfgti forum have had the same issues, poor resistance to fade, increased disc wear rates etc
My 'Pagids' came with foundry casting marks from a foundry in China, the many sets of OE discs I have purchased all came marked with German foundry markings and 'made in Germany' stamped on them, well worth the extra £20 a pair over the ECP tat for the increased performance alone imo  :smiley:
Carbon Grey ED35
Offline Beddie
« Reply #16 on: 29 June 2013, 06:46 »
The fact that the OE ones are stamped 'made in Germany' and if you decode the foundry casting marks stamped into the hub area it tells you which foundry cast them, that was in Germany too  :wink:
With discs, the amount of carbon in the mix is key to performance, the cheap Chinese stuff just doesn't cut it quality wise and myself and many others have had issues with the ECP Pagids and seeing as OE discs if sourced via TPS are only £20 a pair more expensive than the ECP ones it's worth every penny imo
Carbon Grey ED35
Offline jhunter_83
« Reply #17 on: 29 June 2013, 07:56 »
The pagoda discs I bought have made in Germany stamped on them?
Offline pedrod316
« Reply #18 on: 31 October 2015, 20:14 »
I am after a set of oe front discs, can you purchase from them anywhere apart from vw themselves?
Offline Gaz-M
« Reply #19 on: 04 November 2015, 11:01 »
Im an EBC dealer if anyone is after EBC brakes. I will try do a discount if possible too.
The best combination in them is Ultimax Discs and Yellow Pads. Which i run myself too.
