Author Topic: Car starts ok in mornings...but not any other time!  (Read 3629 times)
Offline gazareth
Re: Car starts ok in mornings...but not any other time!
« Reply #10 on: 28 June 2013, 18:28 »
I would check ignition timing as if its to far advanced it wont want to crank over properly and of course when engine gets hot and compression improves it will be even worse. did you check your charging?
Offline james2
  • No scammers please.
« Reply #11 on: 28 June 2013, 20:11 »
Get it scanned / buy a code reader before doing anything else.
You can scan mk3 ? i would get a new battery .Or better still upgrade to a mk4  :whistle:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline gazareth
« Reply #12 on: 28 June 2013, 21:22 »
or upgrade the upgrade and get a mk2 :grin:
Offline Third Rail
« Reply #13 on: 29 June 2013, 10:15 »
Thanks for that advice mate...sounds like it could be the problem. I checked the charging - everything seems fine.
Offline Third Rail
« Reply #14 on: 29 June 2013, 10:16 »
Wanted a MK1...upgrade the upgraded upgrade???? Where will it end?  :grin:
Offline tweed
« Reply #15 on: 29 June 2013, 10:39 »
would not rev past 5000 if thats the case. Does it rev past 5000rpm
Offline Third Rail
« Reply #16 on: 29 June 2013, 12:25 »
Quote
Not tried yet...will give it a go later ta
