Author Topic: passenger side central locking, electric windows and mirrors not working -HELP!!  (Read 1542 times)
Offline amaru
Hi folks,
I've got a problem with my mk4 golf 1.6 match. I've recently bought it but the passenger sides windows are not working, along with the central locking, wing mirrors and the light at the bottom of the door. It seems as though the electrics on that side don't work. The drivers side is totally fine.
I've plugged it into a diagnostic checker and the only thing that could be remotely related to it is;
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
I've opened the door up and made sure everything is connected.
The wires are not wet or frayed.
I havnt changed the battery recently too.
Any help on the matter would be much appreciated.
Thanks in advanced! :smiley:
Amar
Offline mcgee9t2
light on door and central locking could be the door module
locking could also be CCM
not sure if wingmirrors have anything to do with door module, don't think they do so check the fuse for that to start with (unless the other wingmirror is working then it wownt be fuse and could be the motor in that mirror being knakerd or a dodgey wire or something)
Offline amaru
Hi Mcgee9t2
I thought it might be the cmm too. A friend of mine has the same car, so we swapped our ccm's and it still worked, BUT my car has two sets of outputs pins on the ccm, where as the other just had the one (different sizes too). Nevertheless I tried it on my friends and left one of the connectors empty and it still worked...would this mean its not the ccm? Or perhaps the two sets of connectors means one for left side and one for right side?
Also I forgot to mention that the problem is on both the front and back doors on the passenger side.
Thanks for your help mcgee
Offline mcgee9t2
ahh is it just pass side central locking not working? i thought you ment it didnt work at all, in that case it wownt be ccm no and more likely a faulty door module.
bit weird that both front and back have gone thought?
Offline amaru
yeah it is a bit weird, they both went at the same time. the speaker on the left side works, and i think thats the only electrical thing that works on that side. also, the doors are a bit bumpy from the outside, which makes me think that there might have been an accident on that side before i bought it.
will try the door module though, hopefully will do the trick!
thanks for your help mate!
