Author Topic: Help from a genius please?!  (Read 4272 times)
Offline tweed
Re: Help from a genius please?!
« Reply #10 on: 26 June 2013, 10:39 »
Was it running fine?
Sounds like needs mapping to me.
Offline Bellend
« Reply #11 on: 26 June 2013, 10:46 »
I'm with Tweed. What's been done to the ECU?
Where all my moneys went.
« Reply #12 on: 26 June 2013, 10:47 »
Agreed, underfueling is going to be down to the mapping etc.
Offline tweed
« Reply #13 on: 26 June 2013, 18:32 »
Oh and have you got bigger injectors?
Offline Screech16v
  • MK3 20vt AGU
« Reply #14 on: 26 June 2013, 19:07 »
Lol I didn't realise this was a new conversion and has never ran right since build,i agree about remapping  :tongue:
Offline gazareth
« Reply #15 on: 26 June 2013, 19:48 »
you could try squeezing the fuel hose on the return line  to the tank to see if it smoothes the idle out at all as a quick test. best make sure your feed from tank is well secure first though in case it pops off when pressure builds up in line. was the compression dropped and what kind of cam you running?
Offline gazareth
« Reply #16 on: 26 June 2013, 20:07 »
ah just thought of something else. is the cat in exhaust blocked???
Offline Sprakie2008
« Reply #17 on: 27 June 2013, 00:02 »
It is running a brand new set of
G60 injectors which have been change to another new set! It has also been mapped by Wayne Schofield down at ChipWizards and was putting out 184. It's slowly got worse over time it seems though! The exhaust is not blocked, took the lambda out so there was a nice big hole so obviously could let more out, but still didnt solve the problem. Fuel pressure is it 2.5 on idle and goes up to 3 on revs, tried with my mates g60 pump and it is better, but not perfect so I assume it's just over compensating for another fault?
Mk3 Mad!
« Reply #18 on: 27 June 2013, 00:05 »
Maybe it is time to look at an aftermarket managment set up, it sounds like that even mapped it is struggling to cope.
Offline gazareth
« Reply #19 on: 27 June 2013, 00:20 »
try blowing some smoke through the intake ducting just to be sure you got no air leaks before the head. maybe a manifold or throttle body gasket is been pushed out with the charge pressure?
