Author Topic: Panoramic Sunroof Video  (Read 17742 times)
Offline Snoopy
  • Geoff.
Re: Panoramic Sunroof Video
« Reply #10 on: 22 June 2013, 20:08 »
Not a fan of that.
Ugly, noisy and that wind deflector!
Not sure what was wrong with a standard sunroof.
I love a sunroof for the light and air but I would not order that. :cry:
Garage:
35+ years of GTI ownership.
Offline Jimble
  • Moderator
« Reply #11 on: 22 June 2013, 20:09 »
Noisy how?
Offline simonpolly
« Reply #12 on: 22 June 2013, 21:16 »
Noisy how?
when the roof is open its very noisy even a low speeds
Golfgti build quality is average at best.
Offline Jimble
  • Moderator
« Reply #13 on: 22 June 2013, 21:28 »
Noisy how?
Isn't that what the windbreak is for?
Offline simonpolly
« Reply #14 on: 22 June 2013, 21:33 »
Noisy how?
its the wind break that causes the noise,i think its there to stop anything from entering the car e.g flies, hence the reason it traps so many :smiley:
Offline Bill_the_Bear
  • Yes! Wait a minute... No!
« Reply #15 on: 22 June 2013, 21:52 »
Noisy how?
It's just to prevent the turbulence in the cabin, same as if you open the window and then your hair goes all over the place...(if you have any hair that is).  It shouldn't cause any more noise, it will be no more or less noisy than any other sunroof or window for that matter.
Offline simonpolly
« Reply #16 on: 22 June 2013, 22:01 »
Noisy how?
speaking from experience as I have one on my sharan it is noisy more so than any other car I have been in with a sunroof.Also I wouldn't recommend you have it open at high speed . :wink:
« Reply #17 on: 22 June 2013, 22:09 »
I agree, high speed not recommended.  I won't be taking it over 30 with it open.  Last car I had a sunroof on over 30 it would start to resonate the whole roof.  But stick to low speeds and there should be little noise I'd expect?
Offline Jimble
  • Moderator
« Reply #18 on: 22 June 2013, 22:22 »
Noisy how?
Does the one on the Sharan go outside the body when it's open like the mk7?
Offline simonpolly
« Reply #19 on: 23 June 2013, 11:39 »
Yes it looks to be the same roof,the only difference is on the sharan you get another fixed glass panel that is behind the one that moves,effectively it's twice the size .
