Author Topic: Heatsheild fixings/nuts  (Read 3950 times)
Offline Callum_K
Re: Heatsheild fixings/nuts
« Reply #10 on: 20 June 2013, 11:56 »
Mine rattles between 2.5 and 3.5k rpm so is really really annoying!
Offline Millhausen
« Reply #11 on: 20 June 2013, 15:13 »
Generally it's loose because the studs have rusted or it's pulled through the shield, surely?! I've been toying with the idea of removing mine but daren't.
To the guys that have; how many miles do you do a day? General work commute that is.
Offline mrsaunders
« Reply #12 on: 20 June 2013, 15:44 »
No it's the clips that have gone on mine, sheild and nuts are fine
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #13 on: 21 June 2013, 20:19 »
Pulled my front one off before the downpipe last week re-fitted the rear one tho but the fixings aren't great  :grin: mine rattles like mad above 3500rpm now so guess i'll be pulling the shield off anytime soon  :rolleyes:
2000 Mkiv GTi 1.8T AGU
Offline itavaltalainen
« Reply #14 on: 22 June 2013, 14:15 »
usually its the washers that rust and spikes break off... then it becomes loose.
push heatshield to body, push on new washer - use some pliers to push completely flush to heatshield... you won't have rattling anymore.
obviously won't work if heatshield is through but have not seen it come that bad, not even on my >> 200k miles 2 litre estate ;)
other thing that can rattle is heatshield under cat. use a large jubilee clip sort of thing or punched metal band...
Offline mrsaunders
« Reply #15 on: 22 June 2013, 18:18 »
All sorted, found some nuts the fitted on there perfect  :wink:
Offline mrsaunders
« Reply #16 on: 22 June 2013, 18:20 »
Fixed the window today aswell,  :smiley:, just leaves the abs sensor and its all sweet
Offline Millhausen
« Reply #17 on: 24 June 2013, 17:26 »
I was just about to rip mine off when I refit the exhaust but I'll give the new clippy/nut things a go first then. Worth a shot, and the cat has got the dreaded rattle too, plus, what I think to be something in the bay, like the downpipe or something?
  • "1.8T AGU"
« Reply #18 on: 25 June 2013, 21:43 »
Finally got fed up of mine vibrating so got underneath tonight and pulled the last section out  :grin:.....bye bye vibration  :smiley:
Offline Screech16v
  • MK3 20vt AGU
« Reply #19 on: 25 June 2013, 22:07 »
I removed the two front upper shields yrs ago turned out to be the one on the downpipe,sorted with a jubilee clip round the bottom,i wrapped the exhaust to be on the safe side,i now run a 3" downpipe into a 2.5 system so no downpipe heat shield to rattle  just exhaust wrapped
