Golf mk5
need to change my car battery
Topic: need to change my car battery (Read 1942 times)
bhpmad
17 June 2013, 12:14 »
hi all, as a above my car is a 2006 gti with dsg auto box is there any rules around changing the battery?
?thanks
bacillus
Re: need to change my car battery
17 June 2013, 14:44 »
Just get a similar sized one.
I would get a higher rated 77A Bosch one from ECP with their present discount offering.
Without traction power is nothing!
bhpmad
17 June 2013, 18:16 »
will it reset the ecu and cd player code???
bacillus
17 June 2013, 21:11 »
Quote from: bhpmad on 17 June 2013, 18:16
If the cd player originally came with the car from the factory then you shouldn't need a code when you install the new battery. As for your ecu, it should be fine if the car isn't mapped. If you have a revo map then you may need to reapply the revo settings as the car will switch to revo version of stock.
dubber36
Forum addict
18 June 2013, 08:11 »
You'll probable get an assortment of warning lights when you start the car after fitting the new battery, but a short drive down the road, turn off and re-start and they'll all disappear.
bhpmad
18 June 2013, 18:30 »
good good ..thanks for the replys.
Golf mk5
