Author Topic: Help...starting issues MK3 GTI 8V  (Read 2345 times)
Offline jamsplodge
« on: 16 June 2013, 16:19 »
Hi, we have just purchase a golf mk3 gti 8v 1995, been running fine, yesterday went through a puddle, car cut out, wouldnt start, called RAC, it started again, went round corner to check it, the dizzy cap centre contact was missing and just spring.  Today we have replaced the dizzy cap, but is now not starting!  :angry:
Doesnt seem to be any spark at plugs, also tried plug on coil cable and no spark, any suggestions?
Many thanks
Offline itavaltalainen
Re: Help...starting issues MK3 GTI 8V
« Reply #1 on: 16 June 2013, 17:24 »
do you have fuel?
if yes probably coil gone. happened to me not long ago too.
Offline mad4vws
« Reply #2 on: 16 June 2013, 17:26 »
coil pack gone if no spark ,common to go on mk3 golfs... :smug: : :wink:  :cool:
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!!  ON 07813936583
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #3 on: 16 June 2013, 17:49 »
You really need it scanned to give you an idea before you start replacing parts.  The distributor wasn't moved at all?
Offline WadGTI
  • Golf GTI'er
« Reply #4 on: 16 June 2013, 18:13 »
yeah, would go with the coil.
Make sure the ignition coil cable is not breaking up. I had to change both to get mines sorted.
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 16 June 2013, 18:17 »
Dont just.go and buy a coil pack. Check it to see if your getting a spark. Get a spart plug, take the 1st spark lead of (left lead) stick the spark plug in, touch it against the head of the car and get someone to crank it over for you but please do not touch the spark or the metal bit on the lead otherwise you will get a nice shock.
*****MK3 Anniversary*****
*****MK4 GTI T*****
« Reply #6 on: 16 June 2013, 19:47 »
no need for additional spark plug even. pull out the bottom right relay from central electrics (fuel pump relay), the pull off king lead from dizzy. this fits nicely through the crane hole on the engine block. if you can't see a spark there while cranking (just crank with car in neutral with window down so you can stick your hand in and you can see if there's a spark or not).
I bet your coil looks like this....
with the cracked insulation partly removed it becomes pretty apparent why it's not working
« Last Edit: 16 June 2013, 19:50 by itavaltalainen »
