Author Topic: Led day lights help  (Read 3764 times)
Offline rio_gti
Re: Led day lights help
« Reply #20 on: 20 June 2013, 12:27 »
Ill try the sidelight then am I best getting scotch connectors ? Also where is the best place to find an earth under the bonnet
anywhere metal!!!!
Offline Mark b
« Reply #21 on: 20 June 2013, 12:32 »
anywhere metal!!!!
Cheers fella , I'm hoping its easier to do then what I think !
Standard gti 2.0 115bhp 2000 w reg
Offline mcgee9t2
« Reply #22 on: 20 June 2013, 12:37 »
yeah scotch connectors are fine.
personally id proberbly just use crimps cause there easier to find.
take out lights, trace the +ve and -ve wires back a few inches, cut, crimp in another wire then connect up to the drl's. like as shown below
                                                     ___________________ new wire to DRL +ve
+ve From car -----------------Crimp-------------------------------existing wire to side light+ve
                                                    ___________________ new wire to DRL -ve
-ve from car -----------------Crimp-------------------------------existing wire to side light -ve
then the same for the other side
obviously both the new wire and existing wire are going into the crimp but you get the idea. not ideal having 3 wires in a crimp, but possible, ive done it before, or if you can get them there are three-way crimps, but there harder to find in shops and id imagine more costly.
« Last Edit: 20 June 2013, 12:41 by mcgee9t2 »
Offline mcgee9t2
« Reply #23 on: 20 June 2013, 12:40 »
if you want to go really all out then get some heat shrink too, and put on the wire before you crimp then once you have crimped it and tested, move the heat shrink up over the crimp and run a soldering iron over to give a water tight seal
Offline Mark b
« Reply #24 on: 20 June 2013, 12:49 »
Should of brought the drl's with the moduel would of been so much easier ! Just a sham on mk4 you don't have much space for your hands lol
Offline Mark b
« Reply #25 on: 20 June 2013, 13:21 »
do the 2 lower from grills just unclip off ?
Offline GTi_James
« Reply #26 on: 20 June 2013, 13:36 »
ive got 2 splicers on one wire, no problems
Offline mcgee9t2
« Reply #27 on: 20 June 2013, 14:31 »
yes, pull the top down and they will come out.
Offline dom
  • Back in a Mk4
« Reply #28 on: 20 June 2013, 16:35 »
If you were closer to me I'd do it for you, no offence but if you're asking questions like that I can see this ending in tears :whistle:
Offline Mark b
« Reply #29 on: 20 June 2013, 18:15 »
Hahaha got to start somewhere   :laugh:
