Author Topic: Tips for removing exhaust?  (Read 1745 times)
Offline Callum_K
« on: 14 June 2013, 10:50 »
Hi all,
Need to replace the 2 rusty central silencers on my Mk3, have a nice shiny stainless steel section to go in. Any tips for seperating the pieces? Took off the clamp holding my backbox on, tried giving it a good pull and bash witha mallet but it won't budge, seems a very tight fit and probably rusted on! Didn't even get a chance to try the pipe connected to the cat.
Offline dom
  • Back in a Mk4
Re: Tips for removing exhaust?
« Reply #1 on: 14 June 2013, 19:13 »
Penetrating fluid overnight, heat, hammer and chisel :wink:
Offline Callum_K
« Reply #2 on: 15 June 2013, 12:00 »
Ended up using a dremel to cut some slots in the backbox and peeling it loose. Got to attack where it joins the cat today, hopefully won't give me too much grief!
Offline mk2bal
« Reply #3 on: 13 July 2013, 12:40 »
Blow torch to get heat into outer pipe then some good whacks in the right place with a hammer is the way ive always had to do it without mullering it all
