Author Topic: wheel offset - new issue now - what ET to fit 7 or 8 j wheels  (Read 3207 times)
Offline spudboy6
  • Just like a golf ......
My vw wheels i just took off was ET35 (i think estorils are 6" ?) 4x100 and 15" ran them with no dramas , just fitted my new wheels which are still 15" but offset is ET45 and they are 7" on my gauge (no markings)
and the o/s/r rubs on left hand lock ,
does ET equate to mm ? so i need about a 10mm spacer from what i can see from the rub mark ,
does Et work like that and anyone got any suggestions off good spacers to buy that are fairly cheap .
« Last Edit: 14 June 2013, 18:51 by spudboy6 »
Re: wheel ofsets
« Reply #1 on: 11 June 2013, 23:24 »
The higher the et number the further inside the arch it will be, if you run a 10mm spacer that should sort it all ok.
Offline spudboy6
Re: wheel ofsets
« Reply #2 on: 11 June 2013, 23:46 »
Just been out to check had the wheel off and its rubbing on the rear spring platform , i have two options here ,
raise the platform up a notch ( i run a shock and spring kit with stepped rear shock ) think ill try this first as its free
or space the wheel 10mm , think ill just space the wheel out as they look abit lost in the arch as they are
any suggestions on what ones to buy should i get the slip on shim type of hubcentric :?
« Last Edit: 11 June 2013, 23:51 by spudboy6 »
Offline tweed
Re: wheel offset
« Reply #3 on: 11 June 2013, 23:52 »
Your new wheel will be 5mm closer in with those specs. Tyres make huge difference.
If you git coilovers you can take helper out and that gives some room
Offline spudboy6
Re: wheel offset
« Reply #4 on: 12 June 2013, 00:16 »
i have a shock and spring kit on 60/40mm springs but the rear spring platform can be moved up and down in 5mm intervals so will move that up first and get some spacers anyways as the wheels are hiding in the arch , i think ill go for either 12mm or 16mm ,
Re: wheel offset
« Reply #5 on: 12 June 2013, 09:25 »
I would go with 15mm spacers on the rear and 10mm front, hubcentrics ones will be fine with longer bolts.
Just for info et45 is Vauxhall fit.
Offline dom
  • Back in a Mk4
Re: wheel offset
« Reply #6 on: 12 June 2013, 11:45 »
^^^ This, although I'm sure standard MK3 wheels are ET43 :undecided:
Offline spudboy6
Re: wheel offset
« Reply #7 on: 12 June 2013, 17:02 »
Ordered 12mm spacers for the rear (per side )
Will sort the front out next ,
Offline boneybradley
  • Back in a Mk3...
Re: wheel offset
« Reply #8 on: 12 June 2013, 18:43 »
yep
that 2mm won't cause too many issues but curved sidewalls will (try falkens for square sidewalls as they give extra clearance) or go for some slim spacers if you don't want to space the wheels too much (4/5mm?)
Offline spudboy6
Re: wheel offset
« Reply #9 on: 12 June 2013, 20:00 »
I'm running toyo t1r's which are very chunky , the back wheel is nearly 25mm away from the arch so pleanty of room to play with , so ordered the longer bolts and hubcentric spacers for the rear (12mm) going to see how they fit on the front before i put them on the rear but i think 12mm is to much on the front , get them on the rear and decide on spacing for the front . i think front i will go with a 5mm slip on either side , should be alright with 12mm on the rear and 5mm on the front or should i go for some more ?
Been a pain in the bum these wheels and wish I kept my old wheels now but im sure i will be happy as larry once they are all sorted and running sweet
« Last Edit: 12 June 2013, 23:19 by spudboy6 »
