Author Topic: doing it no matter what. had enough!  (Read 2939 times)
Offline budgie
Re: doing it no matter what. had enough!
« Reply #10 on: 10 June 2013, 16:26 »
What windows are you using for vagcom? Ders how to in vagcom section on how to get it to work you neee change ports and run as administrator etc. 5min jobby. Soz about missing pics need to update it :lipsrsealed:
http://www.golfgtiforum.co.uk/index.php?topic=119806.0
xp and that link was for vista
Offline navmk4gti
« Reply #11 on: 10 June 2013, 17:25 »
Follow it and should work. Will need it for xp too. You will need to to do the device manager part and use correct ports
Offline budgie
« Reply #12 on: 10 June 2013, 17:34 »
interface only works with port 3
Offline dom
  • Back in a Mk4
« Reply #13 on: 10 June 2013, 18:36 »
It doesn't matter which port it uses as long as it can establish a connection.
Offline budgie
« Reply #14 on: 10 June 2013, 18:51 »
got it working once and it came up with somthing like loss in presure between turbo and throttle check DV!.   Somthing along them lines anyway.. IDEAS?????....  The turbo was acting up earlier like it wasnt there.. niped into shop and when i came out it was working again????
Offline barrym381
« Reply #15 on: 10 June 2013, 18:59 »
sounds like a boost leak  :sad:
Offline GTi_James
« Reply #16 on: 10 June 2013, 19:00 »
and that its protecting itself from over boosting perhaps?
Offline budgie
« Reply #17 on: 10 June 2013, 19:26 »
whats the dv?  is this going to be a big problem?
Offline barrym381
« Reply #18 on: 10 June 2013, 19:30 »
no its easy to change for a forge 007p or 008
Offline dom
  • Back in a Mk4
« Reply #19 on: 10 June 2013, 19:57 »
DV = Diverter valve :wink:
