Author Topic: What would you do?  (Read 10846 times)
Offline Foreveryoungaus16v
Re: What would you do?
« Reply #40 on: 10 June 2013, 19:50 »
 Few things to look out for when buying lcr would be FULL service history would be a bonus. Uneven tickover, flat spots at 2500 3000 rpm, if the maf is clean,  bodywork paint fade, evidence of water ingress in interior, check rear wiper washer works,  rad fans should come on slow, if fast fan resistors have gone. Thats just a few things. They are well built motors but expensive if not maintained well. As said mission to find a mint one.
« Last Edit: 10 June 2013, 19:52 by Foreveryoungaus16v »
163 BHP (TSR POWER RUN)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #41 on: 10 June 2013, 20:08 »
Split hoses are defiantly gonna be happening all over the shop, Blocked PCV valves, cracks in turbo housing, (cant check unless u remove from car = massive job)  oil in inrtercoolers (their 2, one on each side joined by 1 pipe across front of car. if lots of oil here - turbo rebuild time) cracks in head from overheat due to bottleneck in  crap standard manifold and people not letting the turbo cool correctly, Maf sensors, Coilpacks (have they been recalled)
N75 valve, Diverter valve  - may have been changed but what to, diverter valve needs to be forge recirc type if changed..
Water pump,  these fail for fun on all newer Audi VW Seat Skoda due to plastic impeller, Cambelt goes if the water pump breaks
loads more niggle bits, these engines are awesome when they have had all this sorted
then, has it been mapped ?  if so what torque ?  rods bend, - id teir knocking on the engine, if this happens engine is fooked and will need full rebuild
Nick at carbon tuning said mine is the most loved and best condition 20VT he has ever seen and worked on... mine was a 42k engine and iv rebuilt it, i had many split hoses that will have hindered the performance for the first owner of the engine and also me when i first installed
My maf sensor was fooked, my coilpacks were, iv cahanged my turbo, and even my old K04 had a tiny crack in the turbo housing- its ok but this is on a well looked after turbo
TBH all this applies to all 20VT cars.
take vagcom with you if you have it, drive the car, should hold bost well and turbo should not make a flutter sound
6 speed gearbox is also a known weak point, and a expensive fix so make sure its tight and no noises
Also look for leaks on the rocker cover gasket and the tensioner seal (half mood seal)  these 95% of the engine we get need changing, not a massive job but can make a mess if not sorted
« Last Edit: 10 June 2013, 20:13 by F17BAD »
Not no ordinary GTI....
www.mixcloud.com/kells/
« Reply #42 on: 10 June 2013, 20:14 »
Just go for a civic type r EK9 and you will be the envy of a lot of people :cool:
Offline tweed
« Reply #43 on: 10 June 2013, 20:36 »
Ek9 is a animal in the bends. Handles very well. Good engine if you ask me.
200bhp from a 2.0 na engine is very good. Best vag can do is 150 bhp
Offline F17BAD
« Reply #44 on: 10 June 2013, 20:41 »
Ek9 is just not fast tho, is on paper but real world is a let down. this is the white one with red trim inside?
This is one my mate had on a import, was supposed to be near 200hp, and my mk3 with the standard S3 lump completely shown him up from a standing start through onto a 2 mile long single way carriageway... that was on the standard audi map, no modifications, pretty much equal power..  etc
respect for those Type R's was lost forever
Gavv8
« Reply #45 on: 10 June 2013, 21:24 »
Yeah..with their baseball hats on back to front.....i'm 42 mate and i deserve some comfort... :laugh: but when i'm on a quiet road and no ones looking i like to push on a bit hence why an LCR would suit me.
« Reply #46 on: 10 June 2013, 21:27 »
Seen plenty of boy racers in mk3s with baseball hats back to front too lol. It dont matter what car you have you get them everywhere :rolleyes:
« Last Edit: 10 June 2013, 21:36 by Foreveryoungaus16v »
Offline F17BAD
« Reply #47 on: 10 June 2013, 21:28 »
drive a civic round my way and the Asians will love you  :laugh:
« Reply #48 on: 10 June 2013, 21:29 »
Lol
Gavv8
« Reply #49 on: 10 June 2013, 21:38 »
They'd be more impressed where i live if i bought something with a john deere badge on it.
