Author Topic: The 1.8T Air box/Induction thread  (Read 34525 times)
Offline davemk4
Re: The 1.8T Air box/Induction thread
« Reply #60 on: 14 June 2013, 14:30 »
Mine green paper with no oil defo. And cream plastic edges.
Heatshield would require so serious modding to fit as ive had to bend flat the strut fixing mount for where the heat shield would go as other wise it would rub on the s2000 filter.
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Dalo Harkin
« Reply #61 on: 14 June 2013, 14:35 »
You can get around the heatshield - check on the previous page for a pic of mine fitted
Offline Scott D
« Reply #62 on: 15 June 2013, 00:00 »
doesn't need much work bend the shield and make a bracket for securing to the bolt near battery tray
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline paultownsend
« Reply #63 on: 15 June 2013, 00:10 »
They should not be oiled. But for some reason some manufacturers choose to do so.
Mine was from ECP, green and beige and not oiled.
Paper, so iv read has the best filtering ability.
Offline dom
  • Back in a Mk4
« Reply #64 on: 15 June 2013, 17:49 »
Just fitted mine, I got it from Baxxy but it's from ECP as well. It's slightly oiled (I have the stain on my leg to prove it!). I used a 80-70mm hose from Auto Silicone Hoses which was a really tight fit around the filter and needed a bit of trimming at the MAF end.
The red ties in with the rest of my engine bay nicely :grin:
Room is fairly tight though:
jamie16v
« Reply #65 on: 15 June 2013, 17:50 »
i`m going for a puddle sucker, f**k it!..
Offline navmk4gti
« Reply #66 on: 15 June 2013, 17:55 »
You done a good job there dom. Was going to get my pipercross kit and heat shield on but the rain has fooked up that plan :angry:
Offline dom
  • Back in a Mk4
« Reply #67 on: 15 June 2013, 18:00 »
Go for it, it was a b!tch to get it all fitted due to lack of space and the filter being enormous :grin:
Luckily it's been ok here this afternoon, hopefully it will be the same tomorrow so I can rip out the SAI pump and crap that goes along with it.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #68 on: 15 June 2013, 20:23 »
I had to trim back my TIP slightly for the standard airbox so mine should have a bit more room. I'll have to make up some brackets to move the heatshield slightly and I'm gonna trim a hole in it for my ignition amp
Offline davemk4
« Reply #69 on: 15 June 2013, 21:47 »
Dom mine sits right upto the strut point.....this why im saying heatshield no go... only fifferemce i see is TIP brand difference. Ive had to cut some of loom cover trim that goes to bulk head too
