Author Topic: Drivers door lock rod - sticking  (Read 2501 times)
Offline Deefadog
  • Mk2 16V (November 89)
Re: Drivers door lock rod - sticking
« Reply #10 on: 09 August 2005, 20:30 »
Cheers, so how many rods & how many clips are there?
Offline monzablue16v
« Reply #11 on: 09 August 2005, 22:17 »
There is 1 thick rod from the switch (not in diagram) to a plastic clip on the latch arrowed 2 in this diagram
And 1 thinner rod from the locking pin/knob to the same plastic clip marked 1 in this diagram
BTW 3 is for your internal door handle for opening the door.
take your latch out and you'll see what I'm on about :D
Dead easy with new bits and doesn't take long to do just fiddly.
« Last Edit: 09 August 2005, 22:18 by monzablue16v »
Offline Deefadog
« Reply #12 on: 10 August 2005, 08:19 »
Your a star!
Offline Deefadog
« Reply #13 on: 15 August 2005, 15:42 »
Had a really good look at this on the weekend, and as far as i acn see it's not the rods that are the problem, but the actual metal leaver on the door lock, i must have bent it :( I tried bending it but it is still intermitant, it gets stuck sometimes!
Anyone got a spare drivers lock/catch? (i am not sure what this is called)!
Also it has the plastic arm atached to it which is connected to the two rods, how can i remove this plastic bit, or is it part of the catch?
Offline Deefadog
« Reply #14 on: 31 August 2005, 13:09 »
ok, got this sorted at last, new rod, clip and central locking solonoid ! :)
only one problem, the car locks when it's supposed to open and vise versa. It's the 5 wire one btw
is it just a simple matter of swapping the leads around? i mean is there a wire for locking and a wire for unlocking? and i have them the wrong way around?
Note to self - this was suppoosed to be a 10 minute job - Arggghhhhhh  :grin:
Judderi
« Reply #15 on: 05 September 2005, 16:26 »
yes you should just be able to swap the wires over. One gives a signal on lock and the other on unlock. Get the multimeter on it if y not sure which is which.
Offline Deefadog
« Reply #16 on: 05 September 2005, 19:07 »
cheers, yes it was the wrong way around :)
take care
Offline BobbyT
« Reply #17 on: 06 September 2005, 11:47 »
i had a similar problem, mine wouldnt unlock or lock sometimes, had to play around for ages, in the end i had mine de-locked, and the door pins removed, works fine now using the alarm key fob!
