Author Topic: Agu gear problems  (Read 3386 times)
Offline mk4melv
Re: Agu gear problems
« Reply #10 on: 08 June 2013, 19:06 »
cool thanks jin_c also just a nother stab in the dark would you no if my agu would have a daul mass flywheel or a solid mass ?? sorry to bombard you all just got a lot of problems with the car  :cry:
Offline mk4melv
« Reply #11 on: 08 June 2013, 19:30 »
Also could there be a possibility that little or no gear box oil could cause the same problems I haven't checked yet but it's on my to do list
Offline Jin_C
« Reply #12 on: 09 June 2013, 08:39 »
Unless it has been upgraded it will be a dual mass.
I wouldn't think that the oil would cause the issue however it wouldn't harm changing it considering its age.
1.8T AGU, K03s, 007p, pipercross panel filter, G60 + VR6 clutch and flywheel, silicone TIP, decat + boost hoses, JOM coilovers
Offline mk4melv
« Reply #13 on: 10 June 2013, 22:42 »
cool thanks ive tryed adjusting the cables and no luck ive noticed a lot of slop on all the parts so going to replace all the bushings ect with new i dont fancy getiing a second hand unit from a newer golf as you can not garentee that it will be any better than what ive already tbh
Offline Chris.
« Reply #14 on: 11 June 2013, 00:09 »
What box code you got?
Click For Build Thread
Offline mk4melv
« Reply #15 on: 11 June 2013, 17:20 »
well went into vw today to price up some bits and asked the guys in there and they said get a second hand gear box as they seem to think that the sincro mesh has gone even tho they havnt seen the car at all is this lickly to be the case ? they also said the gear box code is ECW cant really see how the gear box has gone as my last golf was on over 200 thou on the original gear box
Offline Chris.
« Reply #16 on: 11 June 2013, 17:35 »
Definately can align linkages.
What year is yours?
Offline mk4melv
« Reply #17 on: 11 June 2013, 18:38 »
1999 mate
Offline Chris.
Offline mk4melv
« Reply #19 on: 11 June 2013, 22:52 »
yeah that does thank you will have a go at doing it that way over the weekend thanks again
