Author Topic: d.i.y pressure/boost check birmingham area  (Read 2100 times)
Offline pickles
  • Next!!!
Re: d.i.y pressure/boost check birmingham area
« Reply #10 on: 07 June 2013, 20:18 »
im guessing theres a leak somewr in the system
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
jamie16v
« Reply #11 on: 07 June 2013, 20:25 »
http://www.ttforum.co.uk/forum/viewtopic.php?f=2&t=252199
like you said, could be a number of things
Offline zimzee
  • golf gti 1.8t 20v mk4 aum
« Reply #12 on: 07 June 2013, 20:52 »
well this is the reason why i named the post d.i.y pressure/boost check birmingham area as i was hoping that someone not to far from me might have had the kit to do it ...... maf and dv have been replaced so a pressure check is next on the list   :wink:
Offline pickles
  • Next!!!
« Reply #13 on: 07 June 2013, 20:55 »
roll yourself a big fat dooby n give it a good blowback  :laugh:
Mapped
Nearly S3 time  :)
Offline zimzee
« Reply #14 on: 08 June 2013, 16:34 »
smoke pellets would be a better option.....think ill just go the garage as they will most likely have all the right gear
Offline zimzee
« Reply #15 on: 08 June 2013, 19:09 »
If i do decide to test this myself what psi should i test it to, car is completely standard.
