Author Topic: forge recirc innards- new or old??  (Read 2048 times)
jamie16v
Re: forge recirc innards- new or old??
« Reply #10 on: 07 June 2013, 23:04 »
if im not mistaken thats like the old 006?.
Offline davemk4
« Reply #11 on: 08 June 2013, 08:50 »
New style doesnt have seal on bottom... the piston was the only difference the O rinfs were same as vefore 1 on top lip and 2 in the chamber
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline mar_k
« Reply #12 on: 08 June 2013, 12:41 »
The new one DOES have a rubber seal/'o' ring on the bottom of the piston, The bottom of the piston is also flat unlike the one in the above picture,
I will quite happily go take mine out and take a picture.
Offline mar_k
« Reply #13 on: 08 June 2013, 12:54 »
I have copied this pis from Audi-Sport, It clearly shows the seal/'o' ring on the base of the piston.
I can still get a pic of mine if preferred.
http://i147.photobucket.com/albums/r314/sleeper18/ForgeDVserviceplusupdatekit_zpsc05f4e11.jpg
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #14 on: 08 June 2013, 14:51 »
Makes sense, the O ring will seal better than metal
Offline davemk4
« Reply #15 on: 08 June 2013, 14:59 »
Lol maybe does never saw it :-D
Just lubed it up and shoved it in and loved the results :-D :-D
