Author Topic: vr6 into a gti 8v  (Read 3780 times)
Re: vr6 into a gti 8v
« Reply #10 on: 11 June 2013, 21:12 »
8v gearbox is cable clutch on all i believe and gearbox is weak.I would not use an 8v box on a vr myself even if it did fit.Clutch is also smaller and weaker.
8v box will not fit a VR6 due to the bellhousing shape.
Gavv8
« Reply #11 on: 11 June 2013, 21:41 »
True say this. They are VERY weak.
The diff tend to go pop on the dfq's (8v gti boxes)
Mines on 148000 miles and still smooth as silk... :smug:
VW BUSH
« Reply #12 on: 11 June 2013, 22:07 »
I blew an 8v box to bits last Autumn, and I mean bits :grin:
16v aint much better, nothing to do with the box just the riveted diff VW tended to use.
Killed all types through snatching gears and shearing the rivets off :grin:
« Reply #13 on: 11 June 2013, 23:25 »
You can get a kit to replace the rivets with bolts, much better in the long run.
Gavv8
« Reply #14 on: 12 June 2013, 19:01 »
I remember this, didn't you redline it from cold out of your work car park? :grin:
Offline NERF 69
« Reply #15 on: 13 June 2013, 18:49 »
Would it not be easier/cheaper to buy a decent vr6? Plus if you're wanting performance from the swap id spend that little bit more money and time and put a 1.8t in instead the vr6 lump weighs a ton. Thats my opinion though
Sell my Vw??? I'd rather stick wasps up my arse
Offline Foreveryoungaus16v
« Reply #16 on: 13 June 2013, 19:23 »
I agree
163 BHP (TSR POWER RUN)
« Reply #17 on: 13 June 2013, 23:43 »
Buying is always easier however if you have a rust free and tidy shell then it can make more sense to convert.
VR is also a lot easier than 1.8t.
