Author Topic: Thanks GTI_James for the headlight tints, Results inside...  (Read 3713 times)
Offline damien010685
Re: Thanks GTI_James for the headlight tints, Results inside...
« Reply #10 on: 06 June 2013, 16:57 »
Tint ftw!!
Offline rio_gti
« Reply #11 on: 06 June 2013, 17:04 »
up rated your bulbs? i think Nino is using osrams, or you could get the ones from turborevs?
read the small print  :grin:
Offline GTi_James
« Reply #12 on: 06 June 2013, 17:28 »
 :lipsrsealed: i thought that was a line someone had drawn on the screen at work  :grin: o'dear
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #13 on: 06 June 2013, 18:05 »
did any of you lot take the headlight out to do it or in situ?
Offline rio_gti
« Reply #14 on: 06 June 2013, 18:08 »
Out mate it's alot easier as the film is very thick
Offline GTi_James
« Reply #15 on: 06 June 2013, 18:59 »
+1
Offline Rod1-gti
« Reply #16 on: 06 June 2013, 19:10 »
Very nice. I might steal the idea ;)
Offline navmk4gti
« Reply #17 on: 06 June 2013, 19:24 »
Looks very good. Like what youve done with the front bumper :smiley:
Offline Scott D
« Reply #18 on: 06 June 2013, 19:28 »
looks good mate
was it lamni-x you used?
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline GTi_James
« Reply #19 on: 06 June 2013, 20:38 »
looks good mate
its some stuff that was kicking about the merc garage
