Author Topic: Where can I get the sill trim cover strips cheap?  (Read 5484 times)
Offline Khare
  • The bear that khares
Re: Where can I get the sill trim cover strips cheap?
« Reply #20 on: 04 June 2013, 19:48 »
So either £38 inclusive of VAT from TPS or £40 from dealers, inclusive of VAT...Rather use dealers, less hassle. Cheers guys!
Offline GOLF-MK3-GTI
« Reply #21 on: 04 June 2013, 22:58 »
Can someone enquire from tps about a genuine vw vr6 splitter?, I want one.
Thanks.
I did a couple months ago.
£40.....a side!!!!
cheese shady, defo getting one.
Offline dom.joy
« Reply #22 on: 05 June 2013, 12:37 »
TPS sell them £30 a side exc VAT I think. got some 2 weeks ago
Offline g3uvn
« Reply #23 on: 07 June 2013, 17:45 »
I found them extremely hard to source last year, the problem is not the plastic it's the fact it has a metal strip in so it's a pain in the ass to copy as its expensive, therefore not many people do. Ended up going to the dealer, luckily had two strips in stock and wanted to get rid so got them £40 all in, was quoted over £45 each side though!
Offline matty james
« Reply #24 on: 07 June 2013, 23:27 »
try the scrappy, ive seen plenty on mk3s which are in good nick, no rusting metalstrips etc
mk3 gti"s and vr6"s,present a silver mk4 anniversary on adjustable coilovers.
Offline Foreveryoungaus16v
« Reply #25 on: 08 June 2013, 09:41 »
Trims you need to get new.
163 BHP (TSR POWER RUN)
Offline madsb
« Reply #26 on: 08 June 2013, 10:26 »
Otherwise if the rust isn't too bad, just get rid of it by soaking in it baking soda mixed with water (use only a little water). Brush rust off with a metal brush. Afterwards lubricate it with some light lubricating oil with anti-rust preferably. It won't rust again then.
