Author Topic: drilling air filter box  (Read 2185 times)
jamie16v
Re: drilling air filter box
« Reply #10 on: 01 June 2013, 22:10 »
try running it with the cone filter and take it for a blast, put some load on the engine, like from low rev in 3rd and take it up to about 3.5k rpm and let off the throttle fast..
p..s how do you know you havent got any leaks?
Offline welshdean
« Reply #11 on: 01 June 2013, 22:22 »
I don't know 100% mate, but I've checked pipes and they seem to be ok  :embarrassed:
jamie16v
« Reply #12 on: 01 June 2013, 23:49 »
do the sucky sucky tongue test on the vac pipe to the dv :grin: .. if its leaking, then it won`t pull the piston in the dv.
take the pipe that goes to the dv, suck it, and put your tongue on the end of it, if the suction goes then its leaking..
just a little trick i learned from the toph  :laugh:
by the way, i think that pipe i supplied you was 4mm, it might be a little loose for the DV. 3mm is better  :wink:
Offline welshdean
« Reply #13 on: 02 June 2013, 05:24 »
Jamie I've got 3mm on there mate, by the way, are you talking about sucking through that 3mm pipe to do the test
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #14 on: 02 June 2013, 09:03 »
You need to suck the DV nipple :laugh:
Offline GTi_James
« Reply #15 on: 02 June 2013, 09:31 »
i like nipples  :lipsrsealed:
