Author Topic: 1997 8v anni front brakes  (Read 2934 times)
Re: 1997 8v anni front brakes
« Reply #10 on: 27 May 2013, 20:10 »
Just run a 5mm spacer, it will be fine
Offline Foreveryoungaus16v
« Reply #11 on: 27 May 2013, 20:15 »
Thai , theres rs771 and rs772 do you know which one is which? I sold my mk4 version on so don't have them to refer to.
RS771 are the Mk4 ones :smiley:
163 BHP (TSR POWER RUN)
« Reply #12 on: 27 May 2013, 20:16 »
RS771 are the Mk4 ones as per the ebay ad Mark :smiley:
Offline Screech16v
  • MK3 20vt AGU
« Reply #13 on: 27 May 2013, 20:27 »
That would figure as I read boney off here had rs772 which are 7j,cheers james
Offline tweed
« Reply #14 on: 28 May 2013, 08:18 »
So only 2.5mm on each pad. That could well just be the difference in a genuine pad and a after market pad.
I know greenstuff pads are thick. So you might have mk3 wheels, just thicker pads than genuine pads.
Offline gaza2001
« Reply #15 on: 28 May 2013, 19:01 »
hi, just checked wheels they are mk4 ones 6 1/2 j  rs771, so will have to go the spacers root :sad:
