Author Topic: Which Oil pressure switch?  (Read 2109 times)
Offline Mart8V
  • I really should know better by now.....
« on: 08 August 2005, 13:05 »
Getting an occasional buzz on the dash at around 2500-300 RPM as revs drop or in a corner.  Only very intermitent, but levels are fine and no sign of coolent loss or smoke.  Is is the one on the head or the filter housing I need to check / replace?  Only serviced 2500 miles ago, and engine was flushed and then filled with Synta Silver, with a new VAG filter.
Help!
Judderi
Re: Which Oil pressure switch?
« Reply #1 on: 08 August 2005, 13:09 »
Might sound a bit un orthadox but maybe the sensor is working perfectly ok and its telling you that you have a problem such as a blockage in an oilway. Stranger things have happened!  :grin:
But yes the sensor is the easiest 1st thing to check. Not sure which one but i think its the one on the head as the one on the cooler reads the temperature.
Offline Mart8V
« Reply #2 on: 08 August 2005, 16:05 »
How would I check for a blockage?  Is there any miracle cure / fluid I can drop in?
Judderi
« Reply #3 on: 08 August 2005, 16:23 »
I think the only propper way to check for a blockage is to drop all the oil out the engine then remove the sump and clean all oilways. You could also add engine flush before you drop the oil.
Offline Mart8V
« Reply #4 on: 08 August 2005, 17:39 »
Will check the switch as first course, and then may have to get dirty.  Thanks!
Offline ...joe
« Reply #5 on: 08 August 2005, 19:43 »
sounds like an oil problem rather than a switch problem to me. as it happens when you go into a corner basicly your oil gets flug up to one side so if the oil is a bit low or isn't available to be sucked up the pump the buzzer will sound. i know that sounds obvious and i know you said the oil level is fine but the switches only work on pressure. the one on the block is a 0.3 bar one which works when you intiially start your engine, the one on the filter housing is the 1.8 bar one which works when you go over 2000 revs. if it is a switch it'll probably be the 1.8 bar one.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Mart8V
« Reply #6 on: 09 August 2005, 08:32 »
Cheers, Joe.  If an oil problem I am guessing that a full flush and new filter is in order?
Offline ...joe
« Reply #7 on: 09 August 2005, 19:57 »
never hurts!
 use a genuine filter from gsf and vw synta oil, should cost about £16 for both.
Offline Mart8V
« Reply #8 on: 10 August 2005, 09:25 »
Hmm- back to see our cheery friend at your local GSF, then!  Still, he def knows his stuff.......
Offline ...joe
« Reply #9 on: 10 August 2005, 09:38 »
true, he does, just wish he'd smile every now and then!
