Author Topic: How long do abf's last ?  (Read 3299 times)
Offline Len
Re: How long do abf's last ?
« Reply #10 on: 24 May 2013, 13:38 »
Offer the guy £500 and see if he bites!
www.sas.org.uk
www.the-ace.org.uk
Offline Screech16v
  • MK3 20vt AGU
« Reply #11 on: 24 May 2013, 18:11 »
Mine was at 170k before conversion,was still making good power and never let me down.
Offline murraymint
« Reply #12 on: 24 May 2013, 18:21 »
My abf had done 170k, and my current one is on 155k, apart from a slightly lumpy cold idle (turns ot pritty common) both of then ran/run sweet
josh
Offline ttelracs
  • The Fettler
« Reply #13 on: 24 May 2013, 20:33 »
Mines just coming up to 171k and I've just had the cambelt done, but apart from my tinkering it runs sweet and is just about run in !  Should clock up another 30k with no real problems apart from expected bearings, brakes and other service items.  Paid £ 450 for it just over a year ago, a good buy and hasn't let me down....
Offline spudboy6
  • Just like a golf ......
« Reply #14 on: 24 May 2013, 20:54 »
went past this evening and the ABF has gone . but will knock the door tomorrow just to be sure , if not will be looking in the classifieds (Y)
Offline gasketface
« Reply #15 on: 30 May 2013, 11:00 »
Mine had done 202 k and purred.Compression all good,no leaks at all.Mileage means little if the car has been serviced properly.Personally i would investigate a low mileage example more thoroughly than a high mileage one as its common for low mileage cars to suffer more in certain areas because they have had little use.
Resale value is not going to greatly affected either as it only really applies if you have one of the rarer models.
Offline Stirring Moose
« Reply #16 on: 30 May 2013, 18:02 »
A mate of mine bagged himself an ABF for an engine swap into a VW Transporter. Think he said the lump had 204k miles on it when he got it. This being the case he gave it a precautionary strip and inspection and found pretty much nothing wrong. Bores were still minty, cams absolutely as per spec, the lot. Bit of gunge here and there which he cleaned out but other than that no worries. But the donor car did come with a good mechanical service history (again, a case of "shame about the bodywork"...). Basically, a well cosseted ABF seems a pretty tough beast as far as I can see.
S.M.
Love and hate, war and peace, joy and sadness... all just crap that happens between trackdays!
Gavv8
« Reply #17 on: 30 May 2013, 19:11 »
Its usually the gearbox that gives up before the motor i find.
