Author Topic: Belt noise when cold  (Read 4479 times)
Offline mikeorchard
Re: Belt noise when cold
« Reply #10 on: 23 May 2013, 19:31 »
Quick question, could I simply take the belt off and run the car and see if it stills makes the noise? How do I take it off?
Offline hill1975
« Reply #11 on: 23 May 2013, 19:55 »
My car makes the exact same noise, and i think its the actual power steering pump. I sprayed mine with multi spray when it was running, and the noise went straight away.
Offline mikeorchard
« Reply #12 on: 23 May 2013, 20:08 »
Multi spray? Is that like WD40? Where did you spray it?
Offline itavaltalainen
« Reply #13 on: 23 May 2013, 20:22 »
just get a new belt already scrooge  :rolleyes:
(without AC - i.e. water pump running on the ribbed belt you can take it off to test if its the p/s belt but the sound it almost with no doubt just that)
5£ and you can change it in 5 minutes... not worth squirting wd40 on.
put steering wheel to full right lock... then you dont have to jack it up unless it's lowered
lock at the p/s belt, you'll see a nut on the p/s pump with a bolt in there (no 3). loosen that bolt a bit.... don't turn the nut yet.
loosen nuts/bolts 1, 2, 4
turn the big nut at no 3.... take belt off, put new one on... put it tight (should be able to still push through for a few cm)... run engine for a short while, recheck tension, do bolts up - done
VW BUSH
« Reply #14 on: 23 May 2013, 20:31 »
Sense.
Should have done the cam belt and tensioner if you changed the water pump already, 50k is about max for belt and bearing life :wink:
Offline mikeorchard
« Reply #15 on: 23 May 2013, 20:52 »
I thought the interval was 60k? And I only changed the pump because one of the bolts sheared off when I was changing the thermostat.
And tbh I'll be throwing the car away in less than 4 months or trading it in for something newer depending on a job I'm waiting to hear about.
I'll have a go at taking the belt off in the morning and then order a new one if the noise disappears. And it's £3 actually :P
« Last Edit: 23 May 2013, 20:54 by mikeorchard »
VW BUSH
« Reply #16 on: 23 May 2013, 20:57 »
If you're binning it then put up with the squeal :grin:
Offline mikeorchard
« Reply #17 on: 24 May 2013, 10:30 »
Few blasts of WD40 between all the pulleys and the noise has gone. Yay to no longer getting pitying looks whilst waiting at traffic lights...  :drool:
Offline Len
« Reply #18 on: 24 May 2013, 13:36 »
You will need to change the PAS belt soon. Squealing is a sign of a worn or slack belt.
Had my car 10 years now and have changed that belt 3 times so far so it does need doing regularly!
www.sas.org.uk
www.the-ace.org.uk
Offline mikeorchard
« Reply #19 on: 24 May 2013, 17:51 »
It's not squealing.
