Author Topic: Taking a gear box out ?  (Read 2722 times)
jamie16v
Re: Taking a gear box out ?
« Reply #11 on: 22 May 2013, 17:59 »
yep
Offline mar_k
« Reply #12 on: 22 May 2013, 20:42 »
Its on the inside of the 6-speed box's.
Its part of the release bearing, Its uses a CSC. I have just replaced the one in my LCR and its a Gearbox off job.
How are you trying to bleed the system?
You can gravity bleed them, just crack the nipple and let the fluid drain through without pressing the pedal,
Pull the pedal up and leave it up with the nipple cracked. Once fluid comes out tighten it up.
« Last Edit: 22 May 2013, 20:45 by mar_k »
jamie16v
« Reply #13 on: 22 May 2013, 20:46 »
oh dear!  :sad:
Offline daz207
« Reply #14 on: 22 May 2013, 22:23 »
Awww not good lol is it hard to take the box out ?
I will try doing the gravity bleeding way tomoro if not will try the the easy bleed kit but if they dont work i am guessing the slave will have to be changed
Offline mar_k
« Reply #15 on: 22 May 2013, 22:26 »
The easybleed takes 2 minutes to bleed, Gravity bleeding will work but can take time so be patient.
Its harder to remove the 6 speed box due to it being larger.
Get the car up as high as you can, that will help loads. Its pig heavy so make sure you have someone to help you
lift the bugger back in.
Offline Granta Gti
« Reply #16 on: 22 May 2013, 22:32 »
I did a diesel 6 speed and that was on the outside so thought the petrol ones will be similar, sorry! Mk4 gearboxes came out a lot easier if you get the subframe out the way, are you doing it on the drive?
Offline daz207
« Reply #17 on: 22 May 2013, 22:37 »
How long is a long time ? Lol i will be going it on the drive way is there a link on how to take a box out ?
Offline mar_k
« Reply #18 on: 22 May 2013, 22:38 »
It is possible that I'm wrong.
I am basing this on my Cupra R 6 speed which I think is the same as the golf 6 speed?
Its easy to identify which is fitted by looking at the gearbox.
also I would agree it would be easier to remove the subframe,
I unbolted mine and pushed it backwards a bit but can be done without dropping it.
« Last Edit: 22 May 2013, 22:40 by mar_k »
Offline Granta Gti
« Reply #19 on: 22 May 2013, 22:40 »
I don't know cause I have never seen a concentric slave on a vag car they mainly on ford an Volvos
