Author Topic: Very long brake pedal travel  (Read 6547 times)
Offline Craigwilson
Re: Very long brake pedal travel
« Reply #20 on: 21 May 2013, 22:04 »
I all ready have a 23mm master cylinder on it which is bigger than the 16v MC, And trust me it's not that I'm comparing it when I depress my pedal it's only an inch off the floor
Offline Craigwilson
« Reply #21 on: 21 May 2013, 22:05 »
And also my front callipers are twin pots and I was told minimum size of MC that will push them is 23mm
Offline Gambit
« Reply #22 on: 21 May 2013, 22:42 »
Ahh my mistake you have the S2 calipers, yeah bigger master cylinder needed s2 had the 25mm master cylinder
Offline Simeon
« Reply #23 on: 25 May 2013, 12:56 »
Bigger master cylinder is not needed, I have the same set up with 23.3 mm Audi master cylinder and the pedal is firm and brakes are spot on.
VW BUSH
« Reply #24 on: 25 May 2013, 20:51 »
If you have more volume in your callipers a standard MC will have more pedal travel
Offline Simeon
« Reply #25 on: 25 May 2013, 22:57 »
Which is why he's using a larger master cylinder..
Offline Craigwilson
« Reply #26 on: 26 May 2013, 01:19 »
So could my MC be faulty ? Because I have a spare new one I could swap it with.
Offline Simeon
« Reply #27 on: 26 May 2013, 08:22 »
Could be. Did you clamp the compensator when bleeding? Have you tried removing the calipers and hanging them from the struts to get them up higher when bleeding? I had a bit of trouble getting the last bit of air out of my twin pots last time I bled them.
Offline Craigwilson
« Reply #28 on: 26 May 2013, 10:46 »
Yeah the compensator was opened, I don't think there's air in the system because the brakes are good and the pedals not spongy it justs moves a lot, but no harm in trying
VW BUSH
« Reply #29 on: 26 May 2013, 19:09 »
So the 1.0 mm increase over the 16v mc in piston area is equal to the volume you need to displace for the bigger twin pot callipers over the same stroke length?
Forgive me if this has been calculated and I have just not read the post properly
