Author Topic: Burning oil ?  (Read 3708 times)
Offline tweed
Re: Burning oil ?
« Reply #10 on: 20 May 2013, 13:47 »
10w 40 is recommended. Use that!
Different engine use different oil.
5W 30 is diesel engines mainly
5w30 is the proper spec oil for the 1.8t golf/passat (and others)  :nerd:
Did say mainly
but as said 10w40 is the o.e spec oil
Offline spudboy6
  • Just like a golf ......
Re: Burning oil ?
« Reply #11 on: 21 May 2013, 21:21 »
Surely if it was valve stem oil seals if I leave it on over run then boot I again it should smoke ?  I get no smoke when driving just first start up for about 5secods made a little film will upload later
Re: Burning oil ?
« Reply #12 on: 21 May 2013, 21:24 »
Valve stem seals are allowing oil to drop into the combustion chember which is then being burnt off, if you had worn rings it would smoke all the time.
Offline spudboy6
