Author Topic: engine bay and inlet manifold very hot  (Read 2525 times)
Offline daz207
Re: engine bay and inlet manifold very hot
« Reply #10 on: 13 May 2013, 04:52 »
Is there a gaskit for engine code AUQ as the AUQ is not listed in that link ?
Offline Scott D
« Reply #11 on: 13 May 2013, 11:08 »
small port gasket for AUQ
are these gaskets proven to work or a load of BS?
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
