Author Topic: Driver vs GTI (8v)  (Read 6282 times)
Offline Rhyso
Re: Driver vs GTI (8v)
« Reply #20 on: 08 August 2005, 08:51 »
Neither does mine but I got the red trim around the grill!!  :wink:
Offline 92 rocks
« Reply #21 on: 08 August 2005, 19:13 »
I run an 8v Concourse and a 16v daily driver and out of them all i like the 14th valve on the 16v best  :laugh:
Stuck in the 80s? Nope its a 92!
Offline Organisys
  • Old and Slow...
« Reply #22 on: 08 August 2005, 20:40 »
GTI also has lower ride height than the carb models !
 :smiley:
« Reply #23 on: 09 August 2005, 08:41 »
and the 16v is even lower than the 8v GTI ;)
Offline SimonJ
« Reply #24 on: 09 August 2005, 10:14 »
A weber carb made a massive difference to my old 1.6 driver, it may vary from car to car, but before mine felt very sluggish and the weber helped a lot. U have to put up with a manual choke though.  :wink:
Offline Logie
« Reply #25 on: 09 August 2005, 11:01 »
So the real main difference is that the GTI is injection?
Offline Gang*
« Reply #26 on: 09 August 2005, 13:27 »
the driver doesnt seem too far off the gti
« Reply #27 on: 09 August 2005, 13:53 »
Engine wise the difference between the 8v carb & injection models is thus:
1. 1.6 Carby blocks have different crank & pistons to reduce 1.8 block cc to 1.6 (block itself is identical between carby & injection models)
2. Carby head has smaller valves and a coolant hole round the back for the inlet manifold coolant channel, and no injector holes. (1.6 & 1.8 carby heads are the same)
3. 1.8 GTI has more agressive cam
4. GTI engine has oil cooler mounted to oil filter housing
Pretty much it :)
