Author Topic: Wiring power cable from battery for amp  (Read 4614 times)
Offline itavaltalainen
Re: Wiring power cable from battery for amp
« Reply #10 on: 04 May 2013, 17:36 »
no thats not the grommet  :lipsrsealed:
go up and a bit right.... there is a grommet (rubber) black on the bulkhead (on your photo you can just see it left to the coolant bottle - where the weld seem is).... the bit where you've poked in the probe tip is part of the body...
Offline chiefwhosm
« Reply #11 on: 04 May 2013, 18:03 »
I did think it strange for a bolt to be called a grommet, but the grommet you told me about is much, much further up the body of the car than your own picture seems to show, which made me wonder if it was the right one or not - I'll go screw in the bolt again... :)
Offline ant_gti
  • mk3 20v turbo
« Reply #12 on: 04 May 2013, 18:09 »
why not make a hole in the big one above where you put that probe in,thats where mine goes.
« Reply #13 on: 04 May 2013, 18:35 »
I marked it there because there is one TOO :)
Which is easier to get to (and comes out in an easier to access spot behind the tray under the glove box.
Offline chiefwhosm
« Reply #14 on: 04 May 2013, 21:50 »
Thanks - I now have a nice 12.4v supply running the length of the car :)
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #15 on: 05 May 2013, 14:22 »
I take it that is with the engine off mate as you should be getting a nice 14.4v when the engine is running.
Offline chiefwhosm
« Reply #16 on: 05 May 2013, 15:50 »
Yes that was with the engine off, I wasn't starting the engine till I'd put the replacement alternator in. Did a test again today (before alt fitting) and its now 1.4v :-s
Edit: Had a bad earth, once the earth was connected a bit better to a temporary test location (the door stop) the amplifier worked perfectly.
« Last Edit: 05 May 2013, 18:03 by chiefwhosm »
Offline Len
« Reply #17 on: 07 May 2013, 13:08 »
Cheers lads.Just another quick question,ive run the cables for the front speakers down each side of the car under the interior sill trims,will I have any problems with interference from the power cable doing it this way?Could I wrap the power cable in something to stop interference?
Never had any problems myself and I have amped speaker feeds in the same location going to the front doors.
www.sas.org.uk
www.the-ace.org.uk
Offline boneybradley
  • Back in a Mk3...
« Reply #18 on: 07 May 2013, 17:21 »
good quality cables help reduce interference... I used to sell some cheap crap that were 100% unshielded and caused all sorts of crackel n pop!!!
Offline Len
« Reply #19 on: 10 May 2013, 12:44 »
Oh yes most definitely decent cables! For both the speakers and power.
www.sas.org.uk
www.the-ace.org.uk
