Author Topic: Some good news (kinda)  (Read 1856 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« on: 27 April 2013, 09:32 »
Stripped the Golf down last night and the oil feed pipe to the turbo is fine so no need to change it now.
I think I may have found the problem though while trying to wind out the three bolts holding the turbo to the manifold. One was completely stuck and I was having flashbacks of it snapping etc. Out came the WD40 which helped a little bit but not much. Once I got the bolt out this is what I found
So she's out of action until I get another bolt and check the thread on the turbo. I also found what looks like a water leak on the water banjo so it was a worthwhile job
Offline xionsolaris
Re: Some good news (kinda)
« Reply #1 on: 27 April 2013, 11:14 »
Im suprised with that thread how that bolt could be screwed in all the way what is the thread like on the manifold were the bolt came from
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 27 April 2013, 13:21 »
Not sure yet mate, I'll be up there again tomorrow with my tap to clean it up
I've got a feeling something was in there while I was screwing it down...
Offline Rhyso
« Reply #3 on: 27 April 2013, 16:48 »
I bet you could remove the turbo blind folded now  :whistle: :grin: :grin:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 27 April 2013, 17:01 »
Unfortunately, yes.
Took me three hours to get it to the stage of being able to remove it bar the downpipe nuts lol
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 28 April 2013, 20:20 »
Spent an hour or so on it today, tapped out all of the threads for the turbo bolts and got a bit of swarf out of the offending hole, looks like I was right and something was in there; probably something from work while I was getting the studs out. I also ran a die down all the threads on the bolts so everything screws in easily now. Manifold and nuts are also back on but not tight, will sort that next time I go up there and get it all running again
Offline xionsolaris
« Reply #6 on: 28 April 2013, 20:44 »
I hope its tight enough last thing u need is loosing exhasut gas pressure
jockgti
« Reply #7 on: 28 April 2013, 20:46 »
so 3 hours to remove turbo? about the same at a decent garage you reckon?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 28 April 2013, 21:10 »
should only take that long mate yes. The manifold is the biggest PITA as some of the manifold nuts are hidden
Yeah I tried the bolts in the threads and they fit lovely now, no wobble on them at all.
« Reply #9 on: 28 April 2013, 21:20 »
Hope it is the end of your troubles :smiley:
