Author Topic: mk4 aum dial cluster mind of own  (Read 2046 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: mk4 aum dial cluster mind of own
« Reply #10 on: 27 April 2013, 10:25 »
I think you are immo3 mate, best way to check is to see what side your immo symbol is on.
You need VAG Tacho to extract the codes from the clocks and to change the mileage which VW can't do any more. Also immo3 swaps are a bit more involved as you need to match the ECU code to the clocks whereas immo2 to immo3 is quite easy and takes about five mins
Offline davemk4
« Reply #11 on: 27 April 2013, 16:24 »
Fook sake.my  car with key symbol on the left on the rev counter near 7k
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #12 on: 27 April 2013, 17:04 »
immo2 then :afro:
the world is your oyster
Offline davemk4
« Reply #13 on: 27 April 2013, 18:13 »
So if i buy immo2 bora sport clocks and get someone on here on code em ill get miles left etc and funky dials etc?
Offline brewey
« Reply #14 on: 27 April 2013, 18:59 »
MTE is only on immo3.
2000 1.8T ARZ - OEM+
Offline davemk4
« Reply #15 on: 27 April 2013, 19:13 »
Oh god i thought all bora clocks same lol
Offline brewey
« Reply #16 on: 28 April 2013, 21:09 »
Same as with the golfs AFAIK so if you want MTE make sure they are Immo3
Offline davemk4
« Reply #17 on: 28 April 2013, 21:18 »
ohhhh so i can buy immo 3 bora clocks? i dont need immo2 clocks. god this confusing lol so how can i tell what to buy if i want the super duper clocks that do everything ?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #18 on: 28 April 2013, 23:11 »
Get the part number and cross reference with Neils thread over in ukmkivs
