Author Topic: Brake bleeding problems  (Read 819 times)
Offline cobalt6700
« on: 24 April 2013, 08:50 »
Hi guys,
Have been bleeding my brakes up after removing and refitting my calipers, and seem to be having some issues.
I've read up on how they can be a bugger to bleed, but I've not introduced any air at the master cylinder end. The pedal seems very hard when bleeding, and what I can only describe as lumpy. When pumping the pedal to push fluid through, it creaks and squeaks.
Now I've bled all corners 3 times, and now have no air coming through. The pedal is sort of there, but you can slowly get it too the floor. If you start the car up it goes straight to the floor.
From my experience this points to the master cylinder being faulty, what do you guys think?
1993 GTI 8v 5dr matt black and green - the 'sh!tball rally car'
1997 GTI 8v 3dr metalic black - the daily driver
2002 3DR 1.8T AUM silver - the new daily
1993 Jeep cherokee 4L - the weapon :D
Offline mar_k
Re: Brake bleeding problems
« Reply #1 on: 24 April 2013, 18:18 »
Mine did this when I tried bleeding them, I thought I had buggered them,
turns out I needed to bleed the 2 nipples on the master cylinder its self.
Offline cobalt6700
« Reply #2 on: 24 April 2013, 20:42 »
Turns out my master cylinder was buggered.
After bleeding the nipples, and doing an ABS bleed just incase, still same problem.
New master in and bled, pedals back to spot on.
Bloody VW master cylinders. 2nd one I've had do that :(
Offline tshirt2k
  • Been there...Done that...
« Reply #3 on: 24 April 2013, 21:49 »
You can damage the seals by pumping on the pedal to bleed. Ideally use a vacuum bleeder.
Mk3 ABF 16VT Megasquirt V3
Offline cobalt6700
« Reply #4 on: 24 April 2013, 22:18 »
Yeah, will be investing in a pressure/vaccum bleeder, had enough of changing master cylinders!
