Author Topic: H15  (Read 1857 times)
Offline jonesltd
  • MK7 R
H15
« on: 12 April 2013, 15:14 »
I have just took out the h15 bulbs and ha delivered up grade kit well its a blue casing but have proper trouble removing bulb from actually unit? Do I pull the bulb or twist at the base? :(
If you cant find it......Grind it
Offline dubber36
Re: H15
« Reply #1 on: 12 April 2013, 15:48 »
I'd leave it alone. I've seen a T5 round here with these. They look too blue, chavy and really nasty in my opinion.
Offline jonesltd
  • MK7 R
Re: H15
« Reply #2 on: 12 April 2013, 16:10 »
Well at this rate it will be left alone as I can't take bulb out of housing :( it's in my hand but can't get it away from case
Offline andyr
Re: H15
« Reply #3 on: 12 April 2013, 19:24 »
Look at the connector on the new bulbs.... May give you an idea on how to remove the old ones :smiley:
Mk VI Black Pearl GTD.... No Frills, replaced a Black Pearl PD150 Bora, which in turn replaced a Dragon Green VR6 which followed a Dusty Mauve MK III 8v Gti.
Offline jonesltd
  • MK7 R
Re: H15
« Reply #4 on: 13 April 2013, 07:37 »
Can't see the connectors as its in the housing straight from the car and can't seperate it hence I am stuck :(
Offline jonesltd
  • MK7 R
Re: H15
« Reply #5 on: 14 April 2013, 07:10 »
Anyone?
Offline mustard
  • Mk7 R
Re: H15
« Reply #6 on: 14 April 2013, 08:01 »
The H15 Bulb has three connectors on the top, it is a combined bulb and holder, to change it, you simply twist the bulb holder and pull (assuming you have small enough hands).
If you do a google search, you can see an image
