Author Topic: New Clutch  (Read 3633 times)
Offline sharki786
  • GOT BOOST??
Re: New Clutch
« Reply #10 on: 11 April 2013, 19:55 »
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Foreveryoungaus16v
Re: New Clutch
« Reply #11 on: 11 April 2013, 20:03 »
I just brought a new Sachs clutch, paid £110 :cool:
Got my Sachs clutch for £81  :cool:
8v's are cheaper then 16v's Sachs clutches
163 BHP (TSR POWER RUN)
Offline xionsolaris
Re: New Clutch
« Reply #12 on: 11 April 2013, 20:27 »
I think the stage thing is all about the material they use for the friction lining on the clitch which means it has more bite and dosent loose grip as much when running more power eg: clutch slip more advance clutches are those paddle ones which isnt really recommended for road use
Offline sharki786
  • GOT BOOST??
Re: New Clutch
« Reply #13 on: 11 April 2013, 21:20 »
Last time i checked for the 8v gti clutch it was 75ish and thats for a sachs for a luk clutch its less then that and that was from andrew page
*****MK4 GTI T*****
Offline GOLF-MK3-GTI
Re: New Clutch
« Reply #14 on: 11 April 2013, 21:35 »
sharki, my brother just bought a clutch for his skoda octavia 1.9 tdi from gsf, it came in a LUK box, but on the clutch itself, it's stamped Sachs? Weird.
Offline Bellend
Re: New Clutch
« Reply #15 on: 12 April 2013, 00:49 »
Might be a case of order two parts, one cheap shat and one expensive decent thing. Swap boxes and return the expensive box and cheao parts  :grin:
Where all my moneys went.
Offline sharki786
  • GOT BOOST??
Re: New Clutch
« Reply #16 on: 12 April 2013, 04:26 »
Some manufacturers share parts. Like my mate bizzle (on here) has a autoshop and sells quinton hazel clutches and he took one out to show me that it had a luk clutch in it (my dad used to work for QH and he usdd to make the pressure plate (cnc setter/operator) so what QH have done is buy the clutch from luk or sachs and make the pressure plate themselfs (QH)
*****MK4 GTI T*****
